Eagle tree guardian control problem - RC Groups
Oct 19, 2017, 07:23 AM
Having a few problems setting up a eagle trees Guardian, what is happening, in either 2D or 3D, if I move either the aileron or elevator stick there is no control movement on the aircraft until I have moved the transmitter control stick to approx 1/4 deflection then the controls on the aircraft will suddenly move to this 1/4 deflection, probably easiest way to describe is there is a dead spot in the stick center position.
This makes flying very jerky and almost impossible to use for landing where you need fine precise movements.
The 2D and 3D hold is working as it should.
If I deactivate the Guardian this stick center dead spot disappears.
Hopefully I can correct this by changing a setting.
Any help would be much appreciated.
Thanks.
Discussion Eagle Tree Guardian Glitch in 2D mode. EPStutes FPV Equipment 0 Dec 30, 2016 10:11 AM
Discussion Eagle Tree Guardian with Taranis X9D /X8R receiver Zman713 3D Flying 1 Dec 05, 2016 08:30 PM
Discussion Which is better: as3x vs eagle tree guardian Bob meter Electric Plane Talk 12 Aug 09, 2016 08:21 PM
Discussion Spektrum DX9 setup for Eagle Tree Guardian SJN Eagle Tree Systems 2 Aug 04, 2016 10:31 AM
