New project - RC Groups
Oct 18, 2017, 07:08 PM
Videonet's Avatar
Help!
New project
I ask for advice. For an observing project in the sea, near the coast, I wish to be able to put an underwater HD camera with transmission via microwave or wifi in a catamaran-style boat that supports waves and wind, which can be operated with a good range radio of up to 1000 mts, and that supports a weight of 5 kgrs of instruments and batteries. There is something suitable DYS for this project. I think must to be a boat of 150 cm large aproximatelly.
Thanks for any suggestions.
Oct 18, 2017, 07:21 PM
Sounds like your project is stationary under water HD Camera ?? ... with real-time or stored media ?? Would be challenged to transmit with commercial equipment - due to water limiting RF transmission
Your transmission method using microwave ?? ... and transmission distance 1000 meters ... sounds like ... you would need FCC /Ham radio license ... even if using a water surface level transmitting bouy ... which likely would require license from Coast Guard for fixed bouy / anchor boat.
Oct 19, 2017, 03:13 AM
True about using gear that is easily available, but license rule might be different in Argentina.
Some of the techniques used on the Seacharger project might be applicable. That was the solar powered long range trans-Pacific attempt, where satellite communication and GPS were involved. Programming a long voyage and holding station are two facets of the same problem.
Discussion New project. 40" O-Fungle BHOFM Balsa Builders 29 Oct 29, 2015 07:07 PM
Discussion New project, Sbach 342 BHOFM Foamies (Scratchbuilt) 13 Oct 03, 2015 11:10 PM
Build Log My new project with a special frame. Patrasgr Scratchbuilt Multirotor Drones 0 Sep 15, 2015 04:39 PM
