Oct 18, 2017, 05:00 PM
72mhz dipole
anyone experiment with adding a tuned di-pole antenna to your 72mhz rx? if so how did it compare to stock?
Oct 18, 2017, 06:53 PM
vollrathd's Avatar
Don't know about 72 Mhz, but some 30 years ago, there was a sailplane variometer that worked on 27 Mhz. I had one, it only had a range of maybe 800 feet. Tried making a di-pole antenna for it, tuned it up with my grid dip meter. The di-pole antenna didn't make much difference, perhaps since the variometer receiver was designed for a single wire antenna.
The modern day 2.4 Ghz radios have a range measured in miles, far beyond visual line of sight.
Oct 19, 2017, 10:45 PM
I doubt that will work well. RC receivers are an unbalanced single wire antenna connection and the dipole is a balanced antenna. The impedance will be way off, and you would need some sort of parallel ladder line from the RX to the point the dipole splits to do it right. I have no idea of those old RXs have a 50 ohm input or what. But then the stock single wire antenna with no counterpoise is not all that great either as antennas go. But it works.
Discussion UHF antennas for best range and consistency.. ? Semi Rigid dipole on plane +? markm75 FPV Equipment 7 Sep 17, 2016 03:07 AM
Discussion Make a simple"dipole 2.4 ghz antenna" géry 46 Scratchbuilt Multirotor Drones 7 Dec 20, 2015 06:49 PM
Question Vertical dipole antenna, does the Rx needs one too? nonoze FPV Equipment 2 Nov 29, 2015 10:08 AM
Help! Turnstile rx + dipole tx 433 uhf Sanjo FPV Equipment 4 Oct 08, 2015 05:24 PM
Discussion How to make dipole with Corona RP8D1 72mhz RX likevvii FPV Talk 1 Apr 02, 2015 01:24 AM
