3GS FBL Gyro Question - RC Groups
Oct 18, 2017, 03:36 PM
I've got an ERazor 450 FBL with a 3GS FBL gyro controller, but have never gotten the heli to program or fly. Here's what it's doing:
1)When plugged in for programming, only the red led on the unit illuminates. With the software up, it tries to find the unit, but never does. The computer is running Windows 10.
2)If I plug in a 3S lipo, the receiver shows good signal (bound), but the ESC beeps slowly. The heli will not otherwise power up or react to any stick inputs.
I became fed up with the provided radio system, so used Spectrum DX6 programming data with my JR XP8103 running a Spektrum 2.4ghz module. Changed out the receiver to a Spektrum AR7000.
Any thoughts?
RStrowe
Oct 21, 2017, 11:25 PM
as much as I can
beenflying's Avatar
It's been quite a while since I used the 3GS. Have you tried the software from here?
https://www.rcgroups.com/forums/show...S-TG-1-ZYX-etc
Make sure your Rx is outputting signal by connecting a servo directly to the receiver first.
Oct 31, 2017, 07:31 PM
I'll try that. Thanks and I'll let you know.
RStrowe
Help! Anyone know this RX gyro ? FBL controller ?? HELP prozak567 Electric Heli Talk 0 Feb 03, 2016 03:56 PM
Discussion Aware of bad FBL Gyro Bigbond Mini Helis 3 Nov 20, 2015 09:37 PM
Discussion FBL without 3 axis gyro on a 120 CP crash test Timewerx Electric Heli Talk 0 Nov 09, 2015 03:36 AM
Discussion Detrum 3GS gyro cobieg Electric Plane Talk 0 Aug 17, 2013 10:23 AM
Discussion $25 FBL Dynam 3GS 3 AXIS GYRO SYSTEM N8LBV Mini Helis 3 May 20, 2013 12:44 AM
