Oct 17, 2017, 11:07 PM
→ 404 Not Found
Justapoke's Avatar
New Product
Skyzone THEER - 860mm Wingspan EPP FPV Wing KIT / PNP With PDB & LED Board
Heads up on another new interesting looking FPV wing that hits the market.
The Skyzone THEER is a 860mm wingspan black EPP wing with room for a GoPro and FPV cam, and includes options as a PDB with LED
2 versions, available as KIT and PNP:
KIT: Skyzone THEER 860mm Wingspan EPP FPV Flying Wing RC Airplane KIT
https://www.banggood.com/Skyzone-THEER-860mm-Wingspan-EPP-FPV-Flying-Wing-RC-Airplane-KIT-With-LED-Board-p-1213145.html
PNP: Skyzone THEER 860mm Wingspan EPP FPV Flying Wing RC Airplane PNP With PDB & LED Board
https://www.banggood.com/Skyzone-THEER-860mm-Wingspan-EPP-FPV-Flying-Wing-RC-Airplane-PNP-With-PDB-LED-Board-p-1213147.html
Description:
Brand Name: Skyzone
Item Name: THEER
Material: EPP
Wingspan: 860mm / 33.8in
Length: 385mm / 15.2in
Recommended Parts for Skyzone THEER KIT (Not Included):
Motor: 2204 - 2305 KV2300 - KV2600
ESC: 20A - 30A
Servo: 9g x2
Propeller: 5040 / 5045 / 6040
Battery: 3S - 4S 1300mAh - 2200mAh LiPo
Camera: Gopro 5 / Session 4 / Foxeer Box
Features:
EPP material,lightweight and durable.
With strong magnetic hatch and carbon fiber control surface.
With skin packing the wing leading edges and specific position for Vtx,well protection.
With multi-color LED light strip,has adjustable multiple flash modes.
Compatible with Gopro 5 / Session 4 / Foxeer Box camera.
Note: The KIT version does not include any electronic device.
PDB board is NOT included.
Oct 17, 2017, 11:09 PM
→ 404 Not Found
Justapoke's Avatar
PNP included setup:
Description:
Brand Name: Skyzone
Item Name: THEER
Material: EPP
Motor: EX2205 KV2550
ESC: 25A
Servo: 9g x2
Propeller: 5045 3-blade
PDB: 5V/3A 12V/2A with voltage detection fuction
PDB Center Hole Spacing: 30.5mm x 30.5mm
Oct 27, 2017, 06:44 AM
andione1983's Avatar
Looks amazing... Would probably rather something slightly bigger wingspan.. But seems OK.
Oct 27, 2017, 07:44 AM
paultbg's Avatar
looks expensive...very
Oct 28, 2017, 09:56 AM
The area where the battery sits looks a lot narrower than the S800, for example. Could be difficult to get the CG correct, especially if you don't put an HD cam in it.
Dec 14, 2017, 08:50 AM
→ 404 Not Found
Justapoke's Avatar
Nice video cezarepicentr, to bad I can't understand a word of the language.
PNP is now available and in stock:
Dec 15, 2017, 09:39 PM
Cronicash
cronicash's Avatar
Had to 3d print new motor mount. Average quality ply for motor mount delaminated itself merely screwing motor in with supplied screws.
Used Velcro to hold front epo cover on. Made hole through wall between cam bay and main cavity for legend 3 to fit, went for slower but more torque 4kg blue bird servos . Cant use battery over 35mm high. I assume other wood parts that came are intermediate fins? Didnt use any of that rubbish anyways. Running vector with airspeed, Multistar Elite 2205-2350kv built in ESC for more space. 7x3 Folding prop, frsky R9, TBS unify V2, blue beam airscrew, runcam eagle 2. Using it for my personal 1000mah 3s range challenge and is doing better than expected with efficiency. About 2.5 amps draw @ 11.4v to stay at 45kph.
Amount of carbon fibre reinforcing is assuring.
Anything under 35kph @ 1.4kg loaded and more than 20 degree pitch results in tip stall for myself.
Still tuning PIDs and gains on vector for now. Hopefully get some range going and even some Li-ion packs. Love this wing but not fond of its price.
Flys well in 25kph wind https://youtu.be/51tkmPx39dE?t=107
Sorry didnt crop video with garbage at thge start but tip stall around 2:07
Stallage! (3 min 39 sec)
Goes allot better with 4s 1400mah but tip stalling at 40kph (to be expected i guess).
Dec 16, 2017, 12:05 AM
Just my humble suggestion to combat the stalling: you might try moving the CG forward 5mm or so when flying it really heavily loaded. It may even need to go 10mm forward.
Dec 16, 2017, 01:30 AM
Cronicash
cronicash's Avatar
Im flying with a battery lighter and lower spec than recommended,. Only way for me to move it forward would be to start hacking out foam for the mere 10mm. To be honest it is a bit on the lite side but still flew both my skyhunter nano and skywalker mini at 30kph no probs with same gear. Only diff would be mobius cam vs legend 3 (hardly a diff imo). Probably more wing surface adding to the problem vs other small planes?
Dec 16, 2017, 12:50 PM
So 1.4kg is lighter than what the manual recommends? Holy sh*t. What does the manual recommend?
Dec 16, 2017, 01:05 PM
Cronicash
cronicash's Avatar
Manual states recommended parts "Battery:3S-4S 1300mAh-2200mAh"
Im 1.4kg on 1000mah 3s. No flying weight specified. Though flying with such a small lipo it does feel very floaty and lite. Could do with a bit more weight.
Lol, had skywalker mini over 2.2kg
Jan 12, 2018, 11:29 PM
Anyone have a diagram for the pdb?
Mar 25, 2018, 04:26 PM
Good looking wing.
Im looking for a wing in this size, sold my TBS Caipirinha 3S.
I know nothing about Skyzones products.
Are Skyzone better or different in any good ways than for example TBS?
Skyzones first flying wing? Is that good? CG and vobble is always tricky with wings.
It seems unstable in lower speeds, or are the wings in the videos not correctly built or balanced (CG/roll)?
Really small batteries. 4S 2200 the biggest that fits?
I saw another one asking how it it possible to balance without a GoPro.
Price is good/low. Too cheap wings equals lower quality...
What does THEER stand for?
Cronicash, buy a new scale!!! :-D My Mini SkyWalker weight is 324 grams. The Caipirinha was 650 g with GoPro 1 and is similar size as Theer.
Sep 26, 2018, 07:09 PM
Theer Wing: Unboxing (10 min 48 sec)
New Product Eachine Black Wing 680mm Wingspan EPP FPV Wing Kit/PNP D Gains FPV Aircraft 119 Jan 02, 2020 11:22 PM
New Product Reptile Swallow-670 S670 Grey 670mm Wingspan EPP FPV Wing KIT / PNP Justapoke FPV Aircraft 5 Jan 08, 2018 04:43 PM
New Product Reptile S800 V2 SKY SHADOW 820mm Wingspan Gray FPV EPP Flying Wing Racer PNP With FPV D Gains FPV Aircraft 1 Aug 10, 2017 10:31 AM
