This thread is privately moderated by Antic bipe, who may elect to delete unwanted replies.
Oct 17, 2017, 03:14 PM
Data
Antic Bipe construction manual
I have scanned the Antic Bipe construction manual. It is too big to load here.
If you want it mailed to you just send me your email address.
Fly safe.
Charlie
Oct 17, 2017, 11:32 PM
eagle60's Avatar
Probably because a page is a full image and even in pdf the size will not be reduced. If you use a OCR program to keep text as text and you scan the single images to be inserted in proper location and then you produce a pdf most probably you will reduce size a lot. You will need more work, but it will be effective.
Oct 23, 2017, 01:47 PM
Thanks for the advice.
Build Log Proctor Antic Bipe padcom Vintage & Old-Timer Designs 15 Jul 04, 2017 11:34 AM
