Matek FLIGHT CONTROLLER F405-MINI STM32F405 - RC Groups
Oct 17, 2017, 01:40 AM
Dutch RC Reviewer
Dutch 79's Avatar
New from Matek, FLIGHT CONTROLLER F405-MINI
STM32F405, ICM20602, BFOSD, 6x PWM / DShot outputs, 32M Flash Blackbox, 2020 mounting holes
MCU: 168MHz STM32F405
IMU: 32K ICM20602 accelerometer/gyro (SPI)
Support 32K Gyro update & 16K PID Loop
OSD: BetaFlight OSD w/ AT7456E chip
Blackbox: 32M(256) Flash
VCP, UART1, UART2, UART3, UART4, UART5
Built in inverter for SBUS input (UART2-RX)
PPM/UART Shared: UART2-RX
SoftSerial & Camera control supported on S5 & S6
Battery Voltage Sensor: 1:10
Current Sensor: No (FCHUB-A5 option)
BEC 5V: No (FCHUB-A5 option)
LDO 3.3V: Max.300mA for Spektrum RX
I2C1 SDA & SCL available
WS2812 Led Strip : Yes
Beeper : Yes
RSSI: Yes
2x LEDs for FC STATUS (Blue, Red)
6x PWM / DShot outputs without conflict
5x UARTs
1x 14pin top mounted FFC Slot for FCHUB-A5 connection
28x28mm PCB with 20mm mounting holes
w/ 6x silicon grommets M4 to M3
w/ 6x brass grommets M3 to M2
w/ 2x 0.5mm*14Pin 3cm Flexible Flat Cable
You can use it as a mini or together with a FCHUB-A5
Now listed on Banggood https://www.banggood.com/Matek-Syste...rmmds=category
https://www.banggood.com/Matek-Syste...8&rmmds=search
Dutch RC Reviewer
Dutch 79's Avatar
Reserved
Oct 20, 2017, 06:16 AM
Dutch RC Reviewer
Dutch 79's Avatar
Oct 31, 2017, 05:34 PM
Probably a noob question but this FC only makes sense with the FCHUB, right? That does make it really big and heavy though. Why would one choose this FC then?
Nov 01, 2017, 12:37 AM
Dutch RC Reviewer
Dutch 79's Avatar
The FC is lighter than the full size one, so should be less vibrations.
Also it's lower than the full stack
I haven't found use for the single FC without pdb.
Nov 02, 2017, 01:04 AM
Why can't the FC be used without the PDB? There are 4 ESC signal pads on the underside. It appears to be capable of being paired with non-Matek 4in1 ESC and wired without the ribbon cable.
Nov 03, 2017, 05:13 AM
Dutch RC Reviewer
Dutch 79's Avatar
Now available
Nov 06, 2017, 09:38 AM
I can't see why this couldn't be used without the pdb, this pic shows vbat pad on the underside of the board ?
Nov 09, 2017, 12:03 AM
Dutch RC Reviewer
Dutch 79's Avatar
It can be used standalone, but it is also possible to use on a full sized quad by using the pdb
Nov 09, 2017, 10:08 AM
It most definitely can be used stand alone, I have it mounted in a micro stack, 5v to the fc and vbat to the vbat pad I'm really impressed with the build quality and the layout of this fc. Will have to see how it fares after a few crashes ?
Cheers Dutch 79 for bringing it to my attention :d
Nov 10, 2017, 06:47 PM
Anybody know which frame that is that used to demo this new FC? http://www.mateksys.com/?portfolio=f405-mini
Nov 11, 2017, 12:36 AM
Dutch RC Reviewer
Dutch 79's Avatar
I believe it's a demo frame someone made, not for sale I think.
Nov 16, 2017, 11:32 PM
I installed the FC (flashed with latest 3.2.2 hex) on a superlight 4R frame with a spedix 30A full size 4in1 ESC and tornado 1407 motors. With the 32K gyro rate turned on, arming the quad results in the motors stuttering and not spinning up, and unstable motor throttling on the BF motor tabs. I turned off the 32K rate and the quad armed and throttled normally. Don't know if this is a defect of the board or the latest hex file. I have a second FC with the default hex and will test it out soon.
Jan 03, 2018, 04:11 PM
THE KHRASH PAD
Any updates from folks using this board? I need a new "go-to" 20x20 FC, I have some micro builds coming up that won't fit the zeus f4 aio esc. Did you get the ribbon cable working to the spedix 20x20 esc?
Feb 01, 2018, 10:24 PM
what is the 5V used for?
I see vbat but what is the 5 volt used for? If using a 4 in 1 ESC, it must have a 5Volt out to the matek?
New Product Matek Flight Controller F405-AIO Dutch 79 Multirotor Drone Electronics 643 Yesterday 03:39 PM
New Product REVO F4 STM32F405 Flight Controller nitbeat Multirotor Drone Electronics 624 Jan 20, 2018 01:18 PM
New Product Matek F405-OSD BetaFlight STM32F405 Flight Controller /w 32khz Gyro ICM20602 nitbeat Multirotor Drone Electronics 23 Nov 11, 2017 03:19 AM
New Product Matek BetaFlight F405-AIO Flight Controller, Built-in PDB, Dual Bec, OSD, 5 Uarts Livershifter Banggood.com 0 Jun 30, 2017 01:02 AM
Discussion Need help Connecting CC3D REVO F4 STM32F405 Flight Controller to Flysky x6b jeeboo374 Beginner Multirotor Drones 6 Mar 07, 2017 06:53 AM
