DYS 1404 BE1404-4300KV & 6000KV 2-4S Brushless Motor - RC Groups
Oct 16, 2017, 02:11 PM
☢ Self-Proclaimed n00b FPVer ☢
EngineerX's Avatar
New Product
I will soon be running thrust tests on the 4300KV variant of this motor sent in by DYS for review. It's going to be interesting to see how well these can spin 2" to 3" propellers and how these tiny new motors perform as far as flight times and flight characteristics. Also, it'll be interesting to see what configurations on your builds you guys come up with (props, frame, LiPo size, electronics used, and AUW). Recently, we only had (for the most part) 1104 to 1106 motors. There have been several new offerings for this class size and now other micro size motors coming out from other manufacturers such as 1402, 1107, 1108. The flight performance of these micro builds has improved quite a bit with the miniaturization and introduction of FC's and FPV components.
Thrust tests & motor overview coming soon (Test results will be posted in about 2 weeks - sorry for the delay, lots of motors on queue for testing, I'll try my best to speed up testing)
https://www.banggood.com/DYS-1404-BE1404-4300KV-6000KV-2-4S-Brushless-Motor-For-FPV-Racing-Drone-p-1211391.html?p=FR3104108021201212@4
THRUST TESTS:
DYS BE1404-4300KV 3S & 4S Thrust Tests - New Size Motor for your Micro Multirotors (10 min 11 sec)
Oct 16, 2017, 06:02 PM
Forward ever, backward never!
Brainstorm's Avatar
EngineerX: Saw these on BG. I guess 1404 is like a 1304 on steroids. Comparable to when T-motor went from 1306 to 1406 on the original F20. Very curious to hear how they do in your testing!
Oct 17, 2017, 01:47 PM
EngineerX's Avatar
Yes! like a Hans & Franz pumped up 1304 !
I just finished testing a 1304-5000 and also got a 1304-4000 that I'll run on the thrust stand as soon as I get a chance after testing this one. I'm also curious to see how they compare and also see, at least on paper, which motor has the best performance: 1104, 1105, 1106, 1108, 1305, 1402, 1404..... all of a sudden there's too many choices
Oct 17, 2017, 06:23 PM
Brainstorm's Avatar
Speaking of which, Hans and Franz were back in action recently:
Hanz & Franz: Reply to Jimmy the Greek - SNL (3 min 16 sec)
I think 1304 are probably the most under-appreciated micro BL size. Simplicity of t-mount, like 1105/1105, combined with extra torque and efficiency of 13xx size, yet with lower weight. Hopefully, these 1404's will be just as good.
The number of available motors sizes has gone out of control! My suspicion is that manufacturers are trying new sizes just to sell more gear to curious consumers. However, from time to time, they discover a gem.
Oct 27, 2017, 03:11 AM
EngineerX's Avatar
LoL ..... It's always a laugh to watch those skits.
Well, looks like the 1404 is just as good as the 1304. A little bit better than the 1106-4500KV in terms of overall thrust. Armature feels sturdy and 2mm shaft should hopefully be strong enough to survive most crashes.
THRUST TESTS:
Oct 28, 2017, 02:27 PM
Brainstorm's Avatar
EngineerX: Appreciate your review notes and thrust tests on this BE1404-4300KV!
Interesting that it has the 4x12mm mounting pattern, like the larger 1306/1407 motors, rather than 4x9mm of 11xx and 1304. This might show it's intended as a lower weight option for the higher power 3" frames, rather than a high-power option for 11xx frames.
The other spec that struck me is the 9g weight. That's roughly 50 percent heavier than the BrotherHobby 1402 (6g weight). Again, this leads me to believe the BE1404 is positioned to contend with 1306/1407 motors, rather than lighter 11xx options.
Nov 06, 2017, 10:53 PM
EngineerX's Avatar
I think that's right on the money, Aimed at light frames meant for 1304/1407 due to that mounting pattern.
A lot of the weight comes from that extra 2mm of stator height. I've noticed motors gain more weight when going taller on the stator as opposed to going with larger diameter since magnet weight has to increase as well as lots of the iron on the laminations.
Nov 10, 2017, 08:22 PM
Brainstorm's Avatar
Interesting note on the increased weight of taller motors due to longer magnets and iron core. I guess that marks another advantage for shorter pancake type motors.
I wish this 1404 motor would come in a 3200KV version and we could get efficient 4" t-mount props for it. There's a new 1404 motor from RotorX as well. But no 4" props for it either, unfortunately.
Nov 10, 2017, 08:49 PM
i have to note that im loving my 3600kv 1407 on the new hq 4 inch tri props, gobs of power, more than my 5 inch and i can get 7 minutes of light acro. not sure a smaller motor would have enough torque. i do think they are too heavy for my 3 inch though, i have the new 3 inch rotorx props coming for my 1304s, should be sweet.
Nov 13, 2017, 08:04 PM
Dirkdigla666's Avatar
That's likely but the 1402 with its almost 50% less weight also is a directnreplacement to a 1407/1408 motor as its more agile and actually may be faster than both my America themed BH catylystmachinework 1407 4000kv and f20 v2 liteweight builds and they even get to use 3076 triples and 3054 quad props though 1402 gets 3044tx.
Dont let the weight fool you.
Appears the dys needs more voltage with its lower kv to have similar numbers as far as thrust to 1402 and really 1402 thrust is likely much higher with its smaller lipo due to both 8100 and 9500kv take 3s like a walk in the park and run 3044tx triples so most likely producing about same 600 or so grams that the best 1407 motors are pulling on 4s with 3in props pretty much on top of being very efficient.
Gonna be hard for the dys to stamd up to but I'd sure like to buy a set to try out.
If The higher kv could take 4s and a 3025 or 3044tx prop that could make it worth the extra weight of the lipo.
So many goods coming out wish they'd all just be for sale no preorder.
Ml
Might as well get a direct withdrawal from my account from motor company's for new motors,would save time.
Engineerx//////,
Do you have a full set of these dys your flying or just a test motor?
Just wondering in flight what they are like,temps and capable voltage.
Dec 31, 2017, 03:14 AM
EngineerX's Avatar
Originally Posted by Dirkdigla666
Engineerx//////,
Sorry I had not checked back this thread. I did get 4 motors and have plans to try them but I just have not had time do any builds lately.
Jan 10, 2018, 01:43 AM
Engineer X-
Thanks for all of your testing. As an engineer myself, I very much appreciate the work you put in to consistently conduct and publish these motor tests. I've been running the RCX H1304-4000kv's for some time now on 4s with GF3025x2's. Great motor, and I'm curious where it ranks with all the other motors. Were you still planning on testing it?
Jan 10, 2018, 05:26 PM
EngineerX's Avatar
Originally Posted by jamdallen
Engineer X-
Hello there fellow engineer Thank you. I also appreciate you watching my YT channel and reviews.
1304-400KV / 4S / GF3025 sounds like a very good match. RCX was truly "ahead" of the times with their 1304's back when nobody was building super ultralight quads since we didn't have all the miniaturized electronics. I should have the 4000KV somewhere in my box of test motors, I'll try and dig it out and do a couple of quick runs on 3025, 3035x2, and a couple of 2.5" props. I'll just add the results to the 5000KV thrust table.
These micro motors are ending up in some builds that fly amazingly well. Here's a video someone posted on the comments
DYS 1404 - REALACC 1106 - 3' light racer race fun session (1 min 26 sec)
Jan 10, 2018, 05:56 PM
Yes, the h1304-4000 does really well. It just about hangs with the 5" quads. Where 5" qauds have an edge in the straights, the micro makes up for it in the turns. In the video below, my little Poco 135 is shown being chased by a fast GoPro equipped 5 inch.
I suspect the data will show that I should swap my rcx's for these new DYS's for greater speed and similar efficiency. On paper, these 1404-4300 look like the number one micro class motor with the best balance between thrust and efficiency on 3" props.
H1304-4000kv's are on the quad being chased in this entertaining video:
Stay in your lane
https://www.youtube.com/watch?v=xNe4t1xmNJI
Jan 11, 2018, 06:18 PM
EngineerX's Avatar
Stay in your lane
Well, looks like the 1304 is giving plenty of speed and efficiency. Your micro is quite fast. This 1404 may be a bit better perhaps but probably not that much.
That video is 1000x better from having Pink Floyd's Run as soundtrack.
New Product Racerstar BR2204/2205/2206 2300KV 2600KV 2200KV 2-4S Brushless Motor-----Free Review BGjim Multirotor Drone Power Systems 128 Nov 10, 2017 11:36 AM
Discussion DYS 1404 BE1404 4300KV 6000KV 2-4S Brushless Motor For FPV Racing Drone scousethief Banggood.com 0 Oct 13, 2017 07:40 AM
Video Babyhawk XXL with 1106 6000kv motors runs 3 to 4S! surferguy Multirotor Drone Talk 0 Jun 02, 2017 05:13 PM
Help! Should i go with ~3900kv or ~4300kv ? Electric 1/5 scale car needs brushless motor. Hacker.io On-road Cars 19 Apr 01, 2017 01:57 PM
New Product DIY Assemble 2204/2205/2206 2-4S Brushless Motor 0.42*2.8 Copper Wire RDroneW Multirotor Drone Power Systems 0 Mar 22, 2017 05:50 AM
