Can Spektrum DXe Work With V Tails At All? - RC Groups
Oct 16, 2017, 11:03 AM
Can the Spektrum DXe work with V Tail planes at all???
The Spektrum radio guide says no, but what if it is a 3 Channel V Tail and the V Tail acts like Elevators?
Then wouldn't you just set the wing type as a normal airplane and use right stick for roll and pitch and use left stick for throttle?
Oct 16, 2017, 11:22 AM
AndyKunz's Avatar
V-Tail means "Rudder and Elevator combined together." You're not talking about a V-tail if it's only 1 elevator servo driving them.
So yes, it will work for that.
Andy
Oct 16, 2017, 01:51 PM
Andy
Thanks so much for the response.
Ok, so if it is a plane like the Excalibur where the V Tail can work BOTH as an elevator and as a rudder, then the DXe won't work, correct?
Thanks again.
Oct 16, 2017, 02:18 PM
AndyKunz's Avatar
I'm not sure what an Excalibur is, but if it is a V-tail that has both rudder and elevator functions, then the DXe is not the radio for you. You want at least a DX6e.
Andy
Oct 16, 2017, 03:55 PM
Andy
Thank you.
Yesterday, 08:27 AM
DX6e Export to DXE
Hi, I have a DX6e and a friend has a DXe radio, I can configure and bind my 6e to his V-Tail and it functions fine. Is there anyway to export my SPM file to his DXE that uses SPR files? So far I can't get it to work in the Programming interface we downloaded.
I've opened the files in Notepad in an attempt to find the differences and create a file for his DXe, but it's a big confusing file and I'm still combing through them both to find a way.
Yesterday, 08:38 AM
Sagitta Fanboy
No, the two files are not compatible.
The DX6e file exports work on the DX6e and up to the DX20. The DXe only supports its own files.
Yesterday, 11:51 AM
GrayGhost4's Avatar
Thanks again.
You could put in an AR636 receiver in the Excalibur, it can be set for Vtail with the computer program (you will need the programming cable) and then the DXe will work.
Then you can have stabilization and Safe Select if you spend some time learning about the AR636
I use an AR636 in my Roc V-tail, it works very well.
But it is probably better to upgrade your transmitter.
Mini-Review Eachine V-Tail QX110 - Redemption for the V-tail design? (review, work in progress) SoloProFan Micro Multirotor Drones 7 Apr 18, 2017 12:05 PM
Question can i use the spektrum dxe with the multiplex funman? jan knoll Foamies (Kits) 2 Jan 10, 2017 05:07 PM
Discussion Can all props spin the same direction on a v-tail? signal15 Multirotor Drone Talk 1 Jul 04, 2012 03:41 PM
Help! Just got Heli and can't seem to get the simulator working at all Lord1234 Micro Helis 6 Jan 12, 2008 09:26 PM
Help! How repair carbon boom? Broke at v-tail joint so can't wrap with carbon tow.... 4444 The Builders Workshop 9 Jul 09, 2006 05:54 PM
