Oct 16, 2017, 10:56 AM
SHARE TO KEEP LEARNING...
ORNIKIT V1.0 Project
Hi Everyone,
We allready Design Fuselage with Solidworks Software,this Design is based on Spybird Gearbox and for use 3mm. thickness CF or GF Sheet,we now find provider can accept Prototypes or low order quantity for CNC Millig,all comments and posible improvements are well received....Thanks!
Best Regards!
Ornikit.
Last edited by Ornikit; Oct 21, 2017 at 02:04 AM. Reason: Add New Files .step .dwg Design
Oct 27, 2017, 02:48 AM
Ornikit V1.0 CNC Parts are ready!
Hi Everyone,
We allready Cut CNC Parts,material is GF G10(Density 1,94g/cm3),3mm. thickness for Prototypes,now we will assembles other parts and check tolerances.
Best Regards!
Ornikit.
Oct 27, 2017, 11:14 AM
Is it realy your design ? Also 3 mm G10 is unnecessary thick for the frame !
🎥HOW TO MAKE ROBOTIC BIRD | ORNITHOPTER | PART 3 (2 min 42 sec)
Oct 28, 2017, 03:25 AM
Coperation for New Ornithopter Design!
Hi Ztex,
Thanks for your comments,i dont said any moment is my Design,as you can see i use "WE" Word,WE cooperate for this Project.
Best Regards!
Ornikit.
Dec 06, 2017, 04:44 AM
Continue with ornikit v1.0 project!
Hi Everyone,
Anyone want to continue with this Project?,should have CNC Milling Machine and possibility get good material for frame,i will send CNC Files for cutting and List of materials,if anyone interested can contact here.
Best Regards!
Ornikit.
Dec 07, 2017, 03:02 PM
Woof
Awesome!
Excellent work and thanks for your contribution!
I have a CNC machine that I am just starting to use. I had to add dust collection system for cutting G10/CF.
What is your intent for this design? Is the design open sourced?
If you are heading down the open source path then I would very much like to participate.
Big sabu
Dec 08, 2017, 04:07 AM
Start Cooperation!
Hi Cosmic,
Thanks for your interest in this Project,sure we want to share with people can contribute to this Project,frame Design is based in this Parts:
http://www.ee.ic.ac.uk/pcheung/teach..._datasheet.pdf
https://www.ebay.com/itm/Brand-NEW-R...-/182430963416
You can send me your Mail or Skype by PM for received Files for Cutting...and let┤s see how it Works your NEW CNC Machine!!
Best Regards!
Ornikit.
Dec 11, 2017, 12:36 PM
OrniKit V1.0 Parts List!
Hi Everyone!
Check attached File for Ornikit V1.0 Parts List...and is FREE Access,hope other Users can cooperate too in this Project.
ORNIKIT V1.0 FRAMESET CNC CUTTING FILES .STEP FORMAT:
https://fly.red/g54zuh53
Best Regards.
Ornikit.
Last edited by Ornikit; Dec 23, 2017 at 04:34 AM. Reason: ORNIKIT V1.0 FRAMESET CNC QUOTE!
Jan 07, 2018, 02:41 AM
Any Update with CNC Machine?
Hi Cosmic Dog!How are you?
Finally you have any Update with your CNC Machine?We are glad if can Update here...
Best Regards!
Jan 28, 2018, 12:47 PM
bonjour
moi aussi je suis sur le projet de fabriquer un oiseau , mais je trouve pas de plan 3d pour solidworks ou autre, j'ai trouve pas de site en france qui vende des pignons , pouvez vous m'aider
merci d'avance
Jan 30, 2018, 01:45 PM
Frameset Files and Gears Info.
Hi Aliene85,
Allready sent Frameset Files by mail,you contact by YouTube Channel and confirm well received,you want get again?
Please could you share here more Info. or Links about the Pinion and Gears find in you place?Thanks and Best Regards!
Mar 24, 2018, 02:21 AM
Hello sir. I'm very glad you responded to my request. Here is my email lubimyikotik1@yandex.ru . With respect Dmitri
Jul 04, 2018, 09:16 PM
Ayudame a construir un Ornithopter
Hola buen dia
Estoy en una investigaciˇn de sistemas de control y me gustˇ la idea de poder trabajar con un ornithopter, recrear la naturaleza para volar, es por esto que estoy dedicando tiempo libre e invirtiendo de mis recursos para alg˙n dÝa alcanzar a construir un ornithopter con todo y sistemas de control para seguir investigando luego en trayectorias de vuelo automßtico, es por esto que estoy pidiendo ayuda de que si por favor me colaboran compartiendome el archivo solidwork para fresar con CNC, aca en la ciudad me pueden ofrecer el servicio y yo mando a imprimir las piezas.
He intentado hacerlo con eslabones y armadura de madera pero no es lo suficiente resistente como para que sea robusto el sistema, es por esto que me gustarÝa mejorarlo con este dise˝o, yo he intentado realizarlo pero no tengo mucha destreza en solidwork y se me han presentado dificultades , es por eso que optÚ por pedir ayuda. EstarÝa muy agradecido con aquella persona.
El archivo frameset de solidwork me hace falta para iniciar en esta nueva etapa
mi correo es luiscaruv@gmail.com
Jul 04, 2018, 09:21 PM
me podrian ayudar, el archivo frameset de solidwork en el link no funciona
si alguien me pudiera compartirlo
Jul 05, 2018, 03:37 AM
@Luiscaruv, @aliene85
Guys, it would be great if you could post in English language so it might be easier for other people in this forum/thread to reply/get involved...
thanky in advance!
Discussion Need at least Vortex fw v1.0.0.6 installed. Deanthorton Beginner Multirotor Drones 2 Jan 18, 2018 06:06 PM
Discussion $21 MAVlink1.0 enabled OSD setup over CRIUS AIO PRO v1.0 alejamp Multirotor Drone Electronics 2 Feb 24, 2013 05:47 AM
Discussion Easy osd v1.0 or v1.2 borsel FPV Talk 2 Jul 10, 2010 04:35 AM
Idea A nifty tool for you guys/girls that program pics etc it is ASCII V1.0.0 flyman668 DIY Electronics 5 Dec 15, 2004 01:47 AM
