Oct 14, 2017, 05:13 PM
Build Log
Inviata E
After 12 years out, I'm starting on an electric version of this plane.
Self- designed.
48" Span
500 Sq in.
Glow power: .40 Como std port.
Power: 815 W, 900 kv
4S, 5000 mah, 25C
Oct 14, 2017, 05:15 PM
Cores & sheeting at & prepped
Oct 14, 2017, 05:19 PM
Sheeting applied & rough-trimmed.
Oct 15, 2017, 04:34 AM
hobbyreayd's Avatar
building planes takes lots of time,especially designed by yourself,support you.
Nov 22, 2017, 12:12 AM
Attaching /shaping L.E.
Pins in X-pattern, from behind seem to do the best job holding L.E. in place
Nov 22, 2017, 12:22 AM
Fuselage sides and doublers cut out.
-Lightening holes cut out of doublers and doublers attached.
When cutting fuselage sides, I glue the 2 sides together, at the edges, to at least get close to symetry. Irregularities will be handled by 1/4" triangle along the edges, to facilitate rounded corners.
Nov 23, 2017, 01:41 PM
Nice. What is your target weight?
Dec 03, 2017, 10:19 PM
About 4 1/2 - 5 lb, like the glow version.
Dec 03, 2017, 10:34 PM
More work on the fuselage:
Left side attached and jigged up. The jig is an old Fourmost Products fuselage jig, which uses 4 pantograph -like devices to ensure symmetry. It's good for ships up to about.60 Size.
Rudder post & bulkheads added.
Firewall installed, with 3/8" basswood triangle supports.
Dec 03, 2017, 10:50 PM
Left side attached and jigged up. The jig is an old Fourmost Products fuselage jig, which uses 4 pantograph -like devices to ensure symmetry. It's good for sport -type models up to about .60 or.9O size
You may note that I didn't bother cutting lightening holes out of the formers
1) Pick up a half dollar sized piece of 3/32" balsa. How much does it weigh?
2) That's how I install the upcoming flexible pushrods. (Yes, I do have a method of minimizing slop... upcoming.)
Mar 13, 2018, 10:23 PM
After one too many goof-ups, I've started the fuselage over. Working out better, this time.
Fuselage sides pretty much the same as before.
This time, however, I remembered to attach the 2 bulkhead fore & aft of the wing exactly perpendicular to the sides.
Also, rather than cut lightening holes in the 1/32" ply doubler , I went with 1/64".
Discussion E E Lightning HarryC Fuel Jet Talk 4 Mar 11, 2017 04:49 AM
Article E-Jets International 2016 and E-Warbirds kevin Electric Ducted Fan Jet Talk 104 Jan 25, 2017 07:52 AM
New Product HC e-NICO ALES-LMR RTF e-Glider hobbyclub Electric Sailplanes 8 Sep 27, 2016 08:29 PM
Gallery Fokker E.III (E.3) davidterrell80 Scale Drawings and Three Views 2 May 04, 2016 02:25 PM
Discussion E/E Lightning profile slot jet georgy SPAD - Simple Plastic Airplane Designs 0 Apr 17, 2016 11:45 AM
