FuriBee GT 215MM Fire Dancer FPV Racing Drone - RC Groups
Oct 14, 2017, 03:21 AM
dartita's Avatar
New Product
New FuriBee GT 215MM Fire Dancer FPV Racing Drone
5.8G 960H CCD Camera / OMNIBUS F4 32K FC with OSD / 2306 2750KV Brushless Motor
PNP: http://bit.ly/2xF6l8W $175 with RC18OFF coupon
FrSky: http://bit.ly/2xEGjm3 $176 with RC18OFF coupon
FlySky: http://bit.ly/2yKaoG7 $181 with RC18OFF coupon
DSMX: http://bit.ly/2xEukoG $181 with RC18OFF coupon
Description:
FuriBee GT 215MM Fire Dancer sets your heart on fire with the top configuration like X215 Pro and dramatic improvements. The durability of the drone has been optimized since the aircraft has a chassis with 5mm thick arm. The DShot ESC supports 4 x 35A large current, which means that you can enjoy flying with 100 percent throttle.
The most amazing thing is that each of the 2306 2750KV brushless motors can generate up to 2kg thrust, pushing the thrust-to-weight ratio to a new high. With the 960H camera, you can truly enjoy FPV racing.
Main Features:
● 215mm wheelbase full carbon fiber frame with CNC aluminum alloy fuselage, 5mm super thick arm
● High-performance OMNIBUS F4 FC has 32K gyro sampling speed, and integrated OSD
● 4-in-1 BLHeli - S 35A ESC uses DShot protocols, and allows you to fly at full throttle
● Extraordinary propulsion system - 2306 2750KV brushless motor and 5048 three-blade propeller
● 960H camera with 2.1mm lens for 5.8G real-time FPV within up to 1.5km range
Specifications:
General
Wheelbase: 215mm
Frame material: full carbon fiber
Arm thickness: 5mm
Brushless motor: 2306 2750KV
Maximum thrust: 2kg / piece
ESC: 4-in-1 BLHeli - S 35A DShot
Propeller: 5048 three-blade
Antenna: 5.8G pagoda antenna
OMNIBUS F4 Flight Controller
MCU: STM32F405RGT6 32-bit processor
IMU: ICM - 20689 ( SPI ), up to 32KHz
Integrated OSD: yes
Firmware: BetaFlight 3.2.0 OMNIBUSF4SD
Video Transmitter
Frequency: 5.8GHz
Number of channels: 48 ( including RaceBand )
Output power: 25mW / 200mW / 600mW
Image transmission range: 1.5km
FPV Camera
Image sensor: CCD
Resolution: 960H FPV / 1080P HD video
Pixels: 2 megapixels
Lens: 2.1mm, 140-degree FOV
First Impression:
It seems to be very promising! Powerful motors, 5mm thick frame, omnibus f4 fc with osd and a power switchable vtx with pagoda antenna. Let's wait it for the first review.
Oct 14, 2017, 05:08 PM
looks to be a monster! I still funnily enough prefer the design of the x215 pro it is supposed to improve upon (and I'm not a fan of the pink). But specs wise... pretty damn impressive. Hope it doesn't make me regret my purchase of x215 though x215 is cheaper and I've already stretched my budget when including all the extras I bought to go with it so I doubt this is within range anyway for me.
Oct 15, 2017, 07:02 AM
K_Wolf's Avatar
The photos appear to show that the GT 220 has a 1-piece frame but the GT 215 has removable arms.
If that is correct, a photo of the bottom bottom of the GT 215 would be useful to see how the the arms are attached.
Oct 15, 2017, 09:37 AM
dartita's Avatar
The frame seems to be the TransTEC Lightning Race 215mm. It has two screws per arm.
Latest blog entry: Clearance sales up to 70% OFF!
Nov 02, 2017, 06:25 AM
Seems to be very interesting but I a little bit afraid with the gyro sensitivity
The IMU MPU6000 is more robust to noise than the ICM20689 wich is known to be sensitive so are the FC & motors Soft-mounted ? Otherwise did the quad risks to suffers of the giro sensitivity ?
Nov 03, 2017, 07:59 PM
You're right, i just saw the review of the frame wich seems great
TransTec Frog Killer?? Lightning Race 215mm // Overview (12 min 31 sec)
Nov 07, 2017, 03:08 PM
Has anyone received a legit shipping date? I feel bad for the people who has been dealing with this a month longer than I have I bet when the 22nd comes it will just be pushed back again. Sorta regretting my decision to get this and not just build another quad, I think im done with gearbest and banggood its not worth saving a few $
Nov 09, 2017, 06:45 AM
K_Wolf's Avatar
First shipping date was late Oct, then changed to early Nov, mid Nov and now its late Nov.
I have asked FuriBee on their official Facebook page when they expect to be ready to ship (3 times now) and have not -yet- received a useful reply.
Dec 02, 2017, 01:37 AM
Looks like the 1080P statement is a mistake - can anyone confirm?
Dec 02, 2017, 06:53 AM
Fan of just about anything RC
SoloProFan's Avatar
AndyRC has a video up:
FuriBee GT 215 Fire Dancer (34 min 6 sec)
Dec 03, 2017, 01:30 AM
dartita's Avatar
yes, andy confirmed it.
Dec 13, 2017, 05:49 PM
the 2 videos on youtube show that the fpv feed is noisy does anyone have one to confirm that this is the norm?
Jan 07, 2018, 09:49 PM
So after 12-14 packs through this quad, I can confirm a few things:
1. Lines in video are present, and definitely come from esc. I'll try a low esr cap next.
2. Make sure the bell screws aren't too tight. That plus AndyRc's fixes make this quad reliable. They cost ZERO dollars.
3. Floaty. Super floaty. Did I mention floaty? It's plenty powerful for it's weight. I need help taming the float. Only thing that helps is pitching the camera upwards and hauling ass, lol.
4. I've cartwheeled the hell out of this frame. Only thing that happens is the arms loosen a bit. Just blue loctite the screws and don't over tighten the soft mounted screws.
Overall, good buy at $150. For more money it might be worth looking elsewhere.
Jan 08, 2018, 12:01 AM
Where would you look elsewhere, if I may ask? Just curious...
Jan 21, 2018, 08:11 PM
Channels change?
So having a problem here, I haven't flown this baby yet. On the bench after a test hover it seems to have change channels on it's own during the hover test.
Discussion FuriBee X215 PRO 215mm FPV Racing Drone - Owners scousethief Mini Multirotor Drones 243 Jun 15, 2018 04:24 PM
Alert FuriBee X215 PRO 215mm FPV Racing Drone dartita Gearbest.com 3 Aug 28, 2017 05:53 AM
Discussion Diatone Tyrant 215 215mm 5.8G 40CH Naze32 REV6 FPV Racing Drone GeekBuying Geekbuying.com 0 Aug 10, 2016 05:24 AM
Contest Thailand ABC Fire Cross Drone Racing ESCmaker Multirotor Drone Electronics 0 Jan 15, 2016 08:42 PM
