Nov 06, 2018, 05:49 AM
AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Oh wow those sites are just so incredibly spectacular! Are both those videos of the same site? And you can't go there any more?? How terribly sad! And to see the Nyx triple carbon - man, that's a plane many of us wish to have, even today. Really talented flying - had me on the edge of my seat calling for my wife and friend to come and have a look! And nice long stalky grass on the backside for a safe backside landing. I hope you can get back up there one day. Thanks.
Nov 06, 2018, 02:43 PM
the occasional flyer
rothlisburger's Avatar
Awesome video. Japan in fall looks somewhat like the western US.
-David
Nov 06, 2018, 03:55 PM
DS in Training .. .
awesome video < have followed you on IG as well , keep up the good work
Dec 14, 2018, 04:24 AM
Kenneth Paine's Avatar
Great work as usual Sanukiudon.
How do you get to sand and contour your filled spar and balsa trailing edge channels without affecting the bottom surface of the wing section?
Do you protect the foam with tape? What tools do you use?
Kenneth
Dec 14, 2018, 09:05 AM
ninjasloper
sanukiudon's Avatar
Kenneth
The procedure is
1.Insert moving surface core
2.One-sided bagging
3.Insertion of spar
4.Left side bagging
I adjust the moving surface core manually.
Rough sanding uses jig.
Final adjustment is embedded in the styrofoam and adjusted.
Epoxy coating on the styro beforehand makes the work easy.
(For the first time I used wood that is harder than balsa.)
The hardness of the surface of the styro exceeds the wood.
Dec 14, 2018, 02:41 PM
Originally Posted by sanukiudon
The procedure is
2.One-sided bagging
3.Insertion of spar
4.Left side bagging
Thank you very much for your reply.
"Epoxy coating on the styro beforehand makes the work easy."
That is a great idea!
Kenneth
Jan 08, 2019, 08:23 PM
ninjasloper
sanukiudon's Avatar
Painting
No clear paint (first trial)
Jan 20, 2019, 11:55 PM
ninjasloper
sanukiudon's Avatar
Movivg surface cutting finished
Jan 28, 2019, 04:36 PM
AvB
AvB
AvB's Avatar
Really beautiful.
Jan 30, 2019, 07:08 AM
Originally Posted by AvB
Really beautiful.
Yes indeed!
Feb 03, 2019, 01:39 AM
ninjasloper
sanukiudon's Avatar
Thank you AvB!
Thank you Kenneth Paine!
I'll start on the mechanical mounting process
Feb 08, 2019, 04:45 PM
AvB
AvB
AvB's Avatar
Hey Sanukiodon, in the picture of the stab mount saddle on top of the fin - is the wider one for your heavier version and the narrower one for your previous lighter version? Really beautiful work ... I love the clean pushrod tunnel too.
Feb 09, 2019, 02:22 AM
ninjasloper
sanukiudon's Avatar
Your guess is correct!
The heavier version is wide.
Because my inexperience speed is targeted, it is making by speculation.
Alert 1/5 scale Baja 5T- The Panty Dropper Vapor Trails Atlanta Area RC 2 Apr 29, 2017 12:08 AM
Discussion Controlling Cheetah 21.5T Sensored BLDC Motor with PIC18F2431 Cantafford DIY Electronics 0 Jan 27, 2017 03:45 AM
Discussion Cogging with 21.5t tim_s On-road Cars 3 Jul 23, 2016 09:10 PM
Discussion Novak HV 6.5T or Ballistic 550 6.5T AL3xGR Electric Power Cars 7 Sep 27, 2010 02:35 PM
