Spektrum Focal DVR FPV Headset by Horizon Hobby - RCGroups Review
We have a new goggle in the Focal line. The Focal DVR set features HDMI, a bigger aspect ratio, built-in DVR and more! Check it out
A Great FPV Headset with DVR Built-in!
The Spektrum Focal DVR FPV headset is the Fatshark goggles you love with the added benefit of a built-in DVR and much more! The HDMI input allows you to plug in the HDMI input of your choice. Another thing I really like is the selectable aspect ratio but I don't think I'll ever leave 16:9.
Focal DVR FPV Headset - RCGroups.com (14 min 56 sec)
What You Get
A DVR on Your Head
This unit has a DVR built right in. The SD card is located on the inside right between your eyes. Make sure you have it in all the way. There is a ledge that might make you think it is in but double check. Also be careful when removing the micro SD card. The spring is strong enough to send it flying!
Put your micro SD card in and then power up the unit. You will see a red light above the SD card slot that lets you know everything is ready to rock. You can hit the top mounted button to start recording (one beep) and stop recording off (two beeps). It's super easy to do in the goggles and your avi files can be dropped right into your editor.
Image Quality
The Focal DVR has 800x480 optics. The two different aspect ratios come in handy if you need to change for 5.8 or HDMI. I felt like the image I was getting allowed me to see better in the sky and when looking at green expanses. The Mini HDMI input port also allows you to input video and HD digital systems like TV programs, home computing and online gaming.
Bad Eyes?
I can't wear just any goggles. I usually need some magnification. The distance between the optic screens – also known as the Inter-Pupillary Distance – can be adjusted to match the spacing of a user’s eyes. The Focal DVR unit worked great with my eyes. With some adjustments to the IPD I was seeing things clearly.
Love the Receiver
The 5.8GHz video receiver makes you feel confident that you are on the right channel. The LED not only helps you find the strongest signal, it also tells you the exact band and frequency you are on. The scan feature is a great way to actually see the strongest signal available. You can also change channels on the fly.
Wireless Head Tracking
A built-in module allows the Focal DVR headset to communicate with any Spektrum transmitter that has Wireless Trainer Link technology (up-to-date Spektrum AirWare™ firmware required) so you can enjoy a more immersive experience without the cord.
Focal V2 Fatshark Wireless Head Tracking - How To (6 min 53 sec)
This is something I have done and I'm happy to report it works great! After a while you will be intuitively looking around as you fly (and start not to feel that you are going to fall out of your plane).
The Fan - I'm a Fan
The fan on these units is something you have to have. When you are in a pasture in the summer with high humidity you wouldn't be seeing much for long without it. Thanks FatShark!
Battery
I like this battery. It seems like a little thing but you are strapping this thing next to your head. It has a hard plastic case. There is also an LED strip built in to check your battery charge level. I ran a battery checker on my old lipos so this is a plus and one less thing to forget. I also find the battery capacity is enough to get me through a whole FPV session. The FSV1815 adds USB charging support to the standard FSV1803 Fat Shark goggle battery. You can charge the smart battery through the traditional barrel jack (no balance lead required) or via a micro USB cable. This is great for charging on the go or with a mobile USB power bank.
PDF Manual
Here is a direct link to the online manual.
Features
  • Wireless head tracking and channel selection
  • Digital Video Recording (DVR) capability
  • Sophisticated 5.8GHz video receiver with integrated LED screen
  • Built-in cooling fan prevents fogging
  • Adjusts to user’s eye spacing (IPD)
  • Optimized 800x480 optics for a crisp picture
  • Selectable 16:9 and 4:3 aspect ratio viewing
  • Comfortable, foam-padded mask
  • Mini HDMI input port for increased versatility
  • 1800mAh Smart LiPo battery with integrated charger, LED meter and USB port
  • FSV1815 adds USB charging support to the standard FSV1803 Fat Shark goggle battery. Add capacity by charging the smart battery through the traditional barrel jack (no balance lead required) or via a micro USB cable. Great for charging on the go or with a mobile USB power bank.
  • Linear dipole antenna included
Specs
  • Application: FPV
  • Length: 6.66in (169.2mm)
  • Width: 3.15in (80mm)
  • Height: 1.79in (45.5mm)
  • Weight: 10.82oz (307g)
  • Voltage: 7-13V (2S-3S LiPo)
Final Thoughts
This is just about the perfect FPV headset for me. Things I love - the DVR, the aspect ratio, the LED RX (and ability to switch it out if needed), the fan, the battery, the fact it works with my eyes, the crisp video image, the HDMI in (in case I ever get an HD FPV system) and finally the battery. I had zero issues with this unit.
I wanted to make sure I had some milage on it before I did the review. I hit our local field with Jason Cole and we flew some HDMI with his Connex ProSight system. I flew my Theory Type W with them for two days. I flew my Stratosurfer through them as well. Finally I used them to ride along with a glow plane. I think you will see in the video that I was getting great signal even though it isn't a diversity unit. The only weak link in the Focal DVR is going to be your onboard camera, antenna and video transmitter. The image quality is so good I realized I needed to get better cameras!
This is now my number one goggle and what I take with me if I'm headed to the field. I love them.
Thoughts from Jason Cole:
I got a chance to try the Focal DVR's out with my Connex ProSight system with the new HX camera on a MiniDrak at the field. They worked great with the Connex system. While the goggle don't have an HD display, the image was still miles ahead of the standard 5.8 analog video feed. It is such a pleasure to fly FPV with the Connex system as you can see things in much better detail, it just makes the whole experience that much more fun. I would definitely recommend getting the Focal DVR's as the HDMI input will make them last much longer as HD FPV becomes more affordable and prominent.
Learn More
Head over to the Horizon site to lean more about this awesome headset.
Nov 09, 2017, 07:40 PM
retired but learning newtricks
alaFlash's Avatar
So in your how-to video for the head tracker, I notice you have two antennas for dual diversity but the stock package does not have but one antenna. Is it correct to assume you have to buy an aftermarket dual diversity receiver like the FS Dominators and such?
Edit: I researched a bit more and find a two antenna system from Fatshark which is not true diversity, meaning it is just one receiver but with two antennas. I'm sure there are other manufacturers who do make dual diversity modules. Thanks
Nov 09, 2017, 07:52 PM
alaFlash's Avatar
What other goggles use the Spektrum wireless trainer feature for head tracking?
Nov 09, 2017, 09:58 PM
just another rebranded fatshark?
Nov 09, 2017, 10:07 PM
It's good to be geek!
MrSatoV's Avatar
Yep, seems that way. I think instead of pretending it isn't, making us think they think we're all idiots, they should have focused this on the differences - if any other than being orange and gray.
Otherwise they seem just like mine. I'm not sure about the specified voltage input range - I'll have to check for my fatsharks. One thing I HOPE they did for this is change out the fatshark DVR - after all, they're calling "goggles" DVR... and the fatshark one SUCKS. The way they word it, it's like they're saying the Fatsharks don't even have a DVR.
I laughed outloud when I read how they're a fan of the fan. Is it different? Looks the same to me. The vRX? what's so special compared to current 3rd party offerings like La Forge or True-D? Looks cheesy by comparison, if you ask me.
This is so obviously a paid review - I mean infomercial.
UPDATE: Yeah, voltage input is same. Someone please tell me, other than cosmetics and price, what is different than the "original". http://www.fatshark.com/product/domi...adset-goggles/
Nov 10, 2017, 02:15 AM
no difference Mate, Just grey in colour far as I can see. a gutless rebrand.
Nov 10, 2017, 05:30 AM
Maybe you guys should just download the manuals for these (linked in the first post for these ones) and check out the specs before you say it's the 'same as xxx'.
As far as I can tell it is pretty well an upgraded FS Dom V3. The main upgrades to the Dom V3's include;
-FS oled vrx modlule (not diversity but works very well imho). I am currently using this vrx in both my HD3's and Dom V2's and, with the right antenna selection, it works as well as my True-D 3.6 diversity module.
- Headtracker is included. It is wireless using current Spectrum Tx's that have the wireless trainer feature. You can still use a wired cable connection for others.
- There are now 2x aspect ratios for analog. You can select between 16:9 and 4:3. Handy if you have both types of cameras. HDMI is 16:9 of course.
The dvr is the same used in all current FS goggles. I think that the current FS dvr's work very well. I have even upgraded my good old Dom V2 dvr to include this and I am very happy with the results.
Overall, I think that these look like very nice goggles and are a pretty big improvement to the original V2 Focals.
My only concern is that the warranty period is only 1 year. Most FS goggles have a 2 year warranty. Also, it seems that any repairs must be done through HH, not through a Fatshark repair centre. This may not be a big deal for US customers but I'm not so sure how well this is going to work for international customers.
Nov 10, 2017, 11:09 AM
Jim T. Graham's Avatar
MrSatoV - My goal is provide my perspective of whatever product I'm reviewing. While we haven't met in person I'm not one to blow smoke. I am one to brag on something that I find useful. I have had a slew of FPV goggles over the years. This one is my current favorite. It does a lot of things well for me. Your mileage may vary depending on what you are looking for.
When I'm at RC events like Joe Nall or SEFF I get questions on goggles. These are sometimes from RC pilots new to FPV and when I write a review I keep them in mind. I have had goggles in the past with no fan so having one on the Fatshark unit is a big plus. I have had more time with the DVR and it works great for my needs. I'm sorry the review fell short for you but hopefully it will be useful to others.
Nov 10, 2017, 11:24 PM
These look to be pretty nicely featured FPV googles.
I wish they would sell them without the receiver for a lower cost.
I prefer to use this receiver...
https://www.banggood.com/Realacc-RX5...r_warehouse=CN
Nov 15, 2017, 09:54 AM
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Great review. I think I will get a set. I like the wireless head tracking with Spektrum.
Dave
Nov 21, 2017, 08:45 AM
Becoming grumpy old man
aaronredbaron's Avatar
Not exactly, it is the only headset on the market with an integrated wireless head-tracker module, and it works very well with the newest generation of Airware transmitters using the wireless buddy box system. That was one of the big differentiators when Horizon developed the Focal line with Fat Shark... but whatever... details about small marked achievements are inconsequential, right?
... Oh and the integrated USB charger? Yeah you're welcome .....
* for full disclosure I worked on the development team on the Focal line when I worked in Product Development. I am now working on the manuals team, at Horizon still.
Nov 21, 2017, 04:15 PM
Did you also do the manual for this? Like most HH manuals, it's very good. A bit better than Fatshark manuals imho. Maybe they should hire you to do theirs, lol!
https://www.horizonhobby.com/pdf/SPM...nual-Multi.pdf
Dec 18, 2017, 05:59 PM
JulianGoesPro's Avatar
it's really hard to find stuff on those... I feel like I am looking at them since half a year... and not much new is coming up? Whats going on? Are they like never being released or just never in stock or is nobody buying them?
I have a the DomV2s and am thinking about getting a new set either for the wireless headtracking and for having a backup set that's quite similiar...
Dec 19, 2017, 05:49 PM
They are readily available and in stock. If you have questions about wireless headtracking just ping me, glad to help
I need to get more time flying my new PT-17. Classic bipe + FPV + wireless headtracking = modern barnstorming fun!
E-Flite PT 17 Stearman FPV with headtracking! (2 min 46 sec)
Dec 19, 2017, 05:56 PM
I have used mine with 5.8 and 1.3, my RMRC Stratosurfer, Manta, and the Inductrix FPV +. They are still my number one headset.
Article Spektrum Focal DVR FPV Headset Jim T. Graham FPV Equipment 18 Jul 08, 2018 02:07 PM
Discussion New 2017 Spektrum Focal DVR FPV Goggles nickthenorse FPV Equipment 8 Dec 18, 2017 06:02 PM
Article Spektrum - Focal V2 FPV Wireless Headset with Diversity Jim T. Graham FPV Equipment 2 Mar 23, 2017 07:11 PM
Review Eachine VR D2 Diversity FPV Goggles with DVR RCGroups Review Nikolei Zinsli FPV Equipment 4 Jan 24, 2017 01:42 PM
Discussion Planning to Buy The Spektrum Focal FPV Wireless Headset (Read This) Swedflyer FPV Equipment 8 Aug 09, 2016 08:06 AM
