nitrocellulose glue-what do you know? - RC Groups
Oct 12, 2017, 02:46 AM
am trying to learn what is the difference between several cements that are made of nitrocellulose. if they use the same basic ingredient, why 1 is stronger than other?
i used duco for a long time. very strong yes, but was very slow drying. then learned about ambroid. very strong too, and fast drying. but now is out.
testors was not as strong. so sigment.
i see others made in europe too, but are hard to import, or even impossible.
i hope some1 can bring data on the reason why, and if there are other cements that use the basic ingredient, that can be purchased or imported into canada.
and at a reasonable price
please polite, positive and to the point answers only. data. sources.
Oct 12, 2017, 08:01 AM
AndyKunz's Avatar
Nitrocellulose is commonly called Gun Cotton.
Celluloid is base for these glues, dissolved in acetone, MEK, and other solvents.
Andy
Oct 12, 2017, 10:08 AM
about duco:
contacted the company about duco and they said that stopped making it many years ago and the 1s on sale are not theirs and not the same.
http://www.itwconsumer.com/userfiles...2435%20TDS.pdf
Oct 12, 2017, 10:30 AM
An itch?. Scratch build.
eflightray's Avatar
UHU do an 'All purpose Adhesive' on one side of the tube, on the other side of the tube it shows - 'El Pragamento Universal' ).
It smells just like the old balsa cement we used on balsa wood models, pretty sure it is a nitrocellulose, warning says 'Highly Flammable'.
UK advert -- http://www.poundland.co.uk/uhu-multi...-adhesive-60ml
Ray.
Oct 12, 2017, 10:55 AM
A man with a plan
Balsaworkbench's Avatar
Have you seen this? http://www.ebay.com/itm/Nitrocellulo...19.m1438.l2649
Oct 12, 2017, 11:08 AM
tried
Originally Posted by Balsaworkbench
yes, i got it. but does not stick as strong as the original ambroid. i can tell because tested both (i still have a little of ambroid).
Oct 12, 2017, 11:09 AM
looks good
Ray.
thanks for the link. looks good.
but, have you tried it? how strong it feels?
i think you mean "el pegamento universal" (that is what the box says).
now, how do i learn if ship to canada for testing it?
tried the link but does not tell.
and i think the smell comes from the solvent, not the cellulose. but perhaps the solvent plays a role in adhesivity?
Oct 12, 2017, 11:11 AM
A man with a plan
That's interesting. I never used Ambroid. I've always been a CA user. I still like CA but now I'm starting to branch out into other options, just because it's fun and interesting.
I bought a bottle of the ebay glue and tried it. I thought it worked OK, but I have nothing to compare it to. The seller has two thicknesses. Did you get thick or thin? If I remember correctly I got the thick stuff.
Oct 12, 2017, 11:20 AM
just 1
at the time i bought it there was only 1 density. it is about same as ambroid.
Oct 12, 2017, 12:52 PM
Norm Furutani's Avatar
Another nitrate based glue that has been popular with some local So Calif. fliers is full size aircraft covering cement. Super Seam, Sure Seam. Comes in quart cans and is the consistency of model cements. I noticed the manufacturer has changed the formulation and may not be the same as I have used. The link has a lot of info and you can probably contact the manufacturer. https://www.aircraftspruce.com/catal...s/sureseam.php
My experience has been with the original Super Seam and I use it for indoor model construction. A-6, Penny plane etc.
Norm
Oct 12, 2017, 01:05 PM
alive and well
got another link to duco: http://www.itwconsumer.com/devcon-products/index.cfm
so yes, still available.
Oct 12, 2017, 01:50 PM
more data
Norm
thank you very much. very interesting line of products.
the 2 that seem closest to my needs are sure seam and super seam, but dont know what is the difference. i asked the rep in canada but if you know more about this i will appreciate if you tell me what you know.
by the way, i used to fly indoor and used ambroid.
Oct 12, 2017, 02:34 PM
Another avenue to explore is "fletching cement". Used to attach feathers to arrows. Looks like Duco and CA's are popular, but I see other brands/types? available.
Oct 12, 2017, 03:07 PM
Here is a link to the material safety data sheet (msds) for the glue currently being sold under the Duco label. Note that 70 to 80% is acetone and 10 to 20% is cellulose nitrate by weight:
http://www.itwconsumer.com/userfiles...MSDS/62465.pdf
In the link you provided for Duco I noticed that the trademark "Duco" originates with du Pont which has licensed the trademark to Devcon et company so it's not clear that what people used as Duco a couple of decades ago is "the same" as the current Duco.
I also used Ambroid in late 60s and early 70s.
What application for this sought for adhesive are you seeking? A lot of innovative substitutes are being used by modelers today for expired, no longer available or difficult to obtain adhesives and coatings.
Michael in Ontario, Canada
Oct 12, 2017, 05:55 PM
cellulose
as ambroid has been the best for my use am trying to learn about nitrocellulose glues available.
i use it for balsa/spruce/plywood.
i dont mind trying other materials but i think i will stick with this kind.
thanks for your input.
Discussion Converting glow engine to gas fuel - What do I need & What I need to know DYORD Engines 19 May 07, 2017 05:33 PM
Discussion Announcing http://whentoland.com - do you know at what voltage to land? Protocrash FPV Talk 3 Sep 27, 2015 05:09 PM
Discussion . Do you know what this sailplane is? Found! midwest soarer planewrecker Sailplane Talk 0 Sep 26, 2015 09:55 PM
Discussion What do I need to know? jessewong8 Beginner Multirotor Drones 6 Sep 17, 2015 04:37 PM
Discussion Do liberals even know what's in the Iran deal? kenpoprofessor Life, The Universe, and Politics 33 Sep 16, 2015 07:24 AM
