Turnigy 9X 9Ch Transmitter w/ AFHDS 2A System - RC Groups
Oct 11, 2017, 10:12 PM
neosunrise's Avatar
New Product
Just saw this on HobbyKing today. It looks like that they are bringing the old 9x back to life. With the AFHDS 2A system, the radio becomes more reliable and there are a wide range of receivers to choose from. It's still very inexpensive, like $60 for the radio plus a iA8 eight-channel receiver. Not sure if it can be flashed to OpenTX like its predecessor. If so, it would be another nice budget radio for beginners!
Link to the product page: https://hobbyking.com/en_us/turnigy-...2a-system.html
Features:
• AFHDS 2A Protocol
• 8 Model Memory
• Multi-channel Frequency Hopping
• Omni-directional gain antenna
• Unique ID recognition system
• Low power consumption
• SBUS/IBUS and CPPM/PWM support
Transmitter Specs:
Number of channels: 8
Model Types: Helicopter, fixed wing and glider
Frequency range: 2.408-2.475GHz
Transmitter power: Not more than 20dBm
Number of bands: 135
Bandwidth: 500KHz
2.4GHz protocol: AFHDS 2A
Encoding: GFSK
Channel resolution: 4096
Low voltage alarm: Below 9V
Charging interface: None
Antenna length: 26mm
Weight: 690g
Input power: 12V DC, 8 x “AA” (1.5V)
Display: STN semi-permeable positive lattice VA 73 39mm LCD
Color: Grey
Online Update: N/A
Certification: CE, FCC ID : N4ZRM00300
Oct 21, 2017, 08:18 PM
Hmmmmm
Saw that !
Wonder why ?
I do like my 9x , But I dont know about changing the firmware ?
This should be interesting , but I just wonder as there are already a few radios available from Turnigy .
Are they trying to flood the market ? ( Makes sense )
Nov 30, 2017, 10:51 AM
The new Turnigy 9X transmitter is very cheap and corresponds to the old transmitter, only the transmission protocol is now AHFDSA2. Unfortunately, I could only save one model permanently, a second I could bind, but then the first did not work anymore! After playing er9x, last version 821, I can not bind a receiver AHFDSA2 until now. I hope Mike has a remedy.
Jan 06, 2018, 07:02 PM
binaryLV's Avatar
Siegi, could you try this on er9x?
http://openrcforums.com/forum/viewto...=10578#p133388
I just tested this I bought one of the new radios myself, and it does indeed work. I flashed the standard "er9x.hex" to the radio, and I had to change the protocol polarity to negative, and then everything is working!
Edit: Oh, just figured out that you're probably phil on that forum.
Jan 07, 2018, 03:33 AM
What about telemetry ?
Jan 09, 2018, 02:23 AM
interesting
http://www.flysky-cn.com/products_de...ductId=81.html
Jan 09, 2018, 03:20 AM
I was wondering if it was that easy ? ( New module )
Must be some firmware updates as well ?
Jan 20, 2018, 03:15 PM
with er9x I could bind the original receiver with "negative". the tgy flysky i6A and B receivers are causing problems. what I'm surprised the send module flysky fs-RM003 is offered for months but is not available, why ?? With a multimodul the transmitter works perfectly.
Phil is Siegi
https://www.banggood.com/Flysky-FS-R...r_warehouse=CN
Feb 13, 2018, 10:55 PM
deleted
New Product (Updating)New Version Flysky FS-i6S 2.4G 10CH AFHDS 2A Transmitter With FS-iA10B BG Well Mini Multirotor Drones 190 Feb 05, 2018 08:23 AM
New Product Quanum i8 AFHDS 2A Digital Proportional Radio System Mode 1 or 21 Maximuss Actual Radios 1 Jan 11, 2016 05:34 PM
Alert Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) tallflyer Electric Plane Talk 32 May 25, 2014 12:12 AM
Discussion Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) burhead27 Utah Flyers Organization 19 Mar 19, 2011 10:44 AM
