Oct 11, 2017, 12:13 PM
Scuro's Avatar
Help!
RSSI via PWM
I am looking for a OSD on a fixed wing that does not require a FC. Just needed RSSI and voltage.
I believe I found one PowerOSD Race to use with a FrSky S8R.
However, there is very little documentation on the PWM RSSI. Both state that it is the method used for RSSI however the receiver has three cables and the OSD only has a single port.
Would you only plug the signal cable to the OSD?
I've attacked relevant pictures/documentation.
Oct 11, 2017, 03:42 PM
Sagitta Fanboy
The RSSI port has Signal, + and - lines, the latter two are shared with the SBUS and PWM channel ports + and - lines (these are power lines)
Just hook up the signal pin to the RSSI pad on the OSD.
Oct 12, 2017, 04:17 PM
Scuro's Avatar
Thank you for the answer. I was thinking the same thing but could not find any documentation or examples to verify this theory.
Oct 12, 2017, 05:55 PM
Sagitta Fanboy
All standard receivers use a single bus for + and - on the servo pins. Only the various PowerBox/PowerSafe/Redundancy box setups do not use a common power bus on the servo pins.
There are some oddities out there (Some Hitec RX's can be powered seperately from the servo's, some FrSky RX's, specifically the X6R, have thin traces to the S.Port plug so you can't power the servo bus from the S.Port) but even then your servo ports are all common.
New Product Frsky S8R 16CH 3-Axis Stablibzation RSSI PWM Output Telemetry Receiver BG Tobey Radios 25 Sep 25, 2017 07:40 PM
Discussion sp racing f3 connect to fs-ia6 receiver via pwm qav250fsi6 Scratchbuilt Multirotor Drones 3 Sep 15, 2016 12:00 AM
Discussion LED Strip via PWM of receiver txrxvx Multirotor Drone Electronics 0 May 26, 2016 04:16 AM
Discussion cc3d via pwm to R9d? raine_ Beginner Multirotor Drones 4 Feb 29, 2016 06:50 AM
Help! RSSI from PWM source and OSD PRO V_Okto Eagle Tree Systems 4 Jun 13, 2012 04:49 AM
