This thread is privately moderated by 1000MPH, who may elect to delete unwanted replies.
Oct 10, 2017, 11:28 PM
Objects in mirror are losing
1000MPH's Avatar
Opus MCT with Alan Cocconi Stability System
Just picked this up used. Its been through a few hands before it got to me. Preliminary inspection shows its in very good shape. Going to do a little clean up and servo/radio inspection then start in on the programming.
CG: 2-5/8
AUW: 108oz
Fuse: 59.5oz
Wing: 48.5oz
Wing ballast kit: 10oz
Wing Servos: MKS 6125 (3rd bearing frame on flaps)
Ele Servo: Atx 94761
Battery: 4 Cell Sanyo 4/5A 4000mah
Recr: Hitec Aurora 9ch
Oct 11, 2017, 09:46 PM
1000MPH's Avatar
I pulled off 6.3oz of lead taped on top of the battery.
Then mixed up some lead shot and resin and poured 6oz in the nose. I checked first and there was plenty of room in front of the battery and tray.
Some people say that the Opus is slightly nose heavy without wing ballast. Others say the CG at 2-5/8 is perfect.
Oct 12, 2017, 07:41 AM
1000MPH's Avatar
The wing is in great shape. There was 10oz of brass ballast slugs that I have now removed. I pulled the clear servo covers off and inspected the servos and linkages. Then I brushed and vacuumed out the Weldon dirt. The painted surfaces were waxed and polished with meguires cleaner wax.
I will leave the covers off until I have set up the radio.
Oct 12, 2017, 07:43 AM
1000MPH's Avatar
The flaps only drop about 45, the horn touches the bottom wing skin. If I relieved the skin around the horn I don’t think I’ll get much more throw due to the geometry. I will try to live with 45 flaps or change horns somewhere down the line.
The ailerons don’t have a huge amount of throw but should be plenty. The linkage is robust.
Oct 12, 2017, 07:57 AM
1000MPH's Avatar
The elevator servo is an Airtronics 94761 with an aluminum arm and ball link on one end and clevis on the other. Looks like a good job on the install and a strong setup.
Oct 12, 2017, 10:33 PM
1000MPH's Avatar
The battery and electronics have been reinstalled.
Nov 07, 2017, 12:31 PM
1000MPH's Avatar
Flew the Opus this past weekend. Alan was able to dial it in perfectly with a few minor tweaks.
Added 2 TX mixes for temperature and speaker box channel selection.
Dialed in the Pitot tubes for more accurate airspeed readings.
Lowered the gain at higher speeds and increased at lower speeds.
Made a small aileron trim adjustment.
After the updates, most speed readings were within 2mph of radar readings.
I think I got a max airspeed of 242.
Oh, and the plane flew beautifully.
Absolutely amazing!
Discussion Opus MC3 & MCT Builds & Mod's Jantar2A Dynamic Soaring 1472 Apr 07, 2019 05:25 PM
New Product Alan Cocconi Stability Augmentation System Aerogance Dynamic Soaring 191 May 10, 2018 08:39 PM
Help! looking for a Cocconi Gyro Stability system L.A.R.S. Dynamic Soaring 1 Jan 09, 2015 07:16 PM
Discussion Opus MCT - What's the craic then? slopetrashuk Dynamic Soaring 11 May 12, 2008 05:05 PM
Discussion Introducing the Opus MCT daboz Dynamic Soaring 35 Nov 03, 2007 05:56 AM
