Oct 10, 2017, 03:55 PM
Gluing servos into foamies
I've used epoxy to hold servos in place in a foam aircraft, and I see the bond between the epoxy and the case has failed.
I've heard of guys using silicone or shoe goo.
What alternatives are out there.?
What have people used with good success?
Jim
Oct 10, 2017, 04:40 PM
A man with too many toys
I use Hot Glue. I have never had a glue failure. It's also very easy to remove using denatured alcohol (available at point stores and Walmart).
Other types of glue and you rip out big chunks of foam is you ever have to replace a servo.
Oct 10, 2017, 06:28 PM
More information: I did say foamie. It's a foam airframe, but not a park flyer. It's EDF.
I'm not going to trust a fast airplane to hot glue.
I'd use hot glue on a park flyer.
Jim
Oct 10, 2017, 06:38 PM
If you really want strength then you should epoxy in some servo rails and a 1/16 plywood sheet over that for more glue area. Then bolt them in. If I had a large expensive high performance foam airplane that's the way I would do it.
Oct 10, 2017, 06:49 PM
AMA 424553
RRHandy's Avatar
This is what is used in assembly in China.
http://www.ebay.com/itm/5-X-704-High...19.m1438.l2649
Oct 10, 2017, 09:02 PM
No retreat no surrender
newguy's Avatar
I have had good luck with welder brand glue on a Panther EDF. Fun plane..
Oct 11, 2017, 08:34 AM
Quando Omni Flunkus Moritati
mm2icbm's Avatar
I've used this with good results. I've never had to remove any servos after gluing them with this, so I don't know how easy/difficult that might be.
Oct 11, 2017, 09:48 AM
Hey, watch this!
Raymond-leflyr's Avatar
I ruined a servo gluing it into a foamy some years back. Just a wee bit of glue got inside and locked something up. Since then I just wrap a single layer of masking tape around the body of the servo - sealing the seam between the two parts of the body. I've never use CA to glue a servo but I'm pretty sure it would work okay. P.S. the servo I ruined was a real cheap and likely didn't have the tightest tolerances.
Oct 11, 2017, 10:01 AM
AndyKunz's Avatar
I use standard GE Silicone II. It cures with an alcohol smell, not vinegar - THIS IS IMPORTANT! The caulks that make a vinegar smell are putting out acidic fumes, and this WILL damage your servo. The type that makes an alcohol smell do not attack the electronics.
Andy
Oct 11, 2017, 10:50 AM
mm2icbm's Avatar
+10. Good points from both Raymond and Andy.
Oct 11, 2017, 01:50 PM
Pro Hoarder
turbonut's Avatar
Plus one to what Andy said..I use the fish tank silicone...no bad stuff in that kind and easy to find
Latest blog entry: In flight
Oct 11, 2017, 02:31 PM
Thanks everybody
Andy and Turbonut: that's exactly what I was looking for.
Oct 13, 2017, 01:46 PM
-insert witty saying here-
Hemikiller's Avatar
Andy
+1
...and I've used hot glue on EDFs with zero issues. The glue is most often stronger than the surrounding foam.
Latest blog entry: ECSF 2017 SWap Meet - 4/2/17...
Oct 24, 2017, 09:59 PM
Bring her in
FlybyDan's Avatar
You could test out Loctite GO2 glue available at HomeCheapo. It sticks good to foam, plastic wind shields, covering, wood.
Question servo mounting: wrapped with tape and glued rhodesengr Sailplane Talk 22 Aug 27, 2018 03:40 PM
Discussion How to remove servos glued to EPP with CA? quietflyer The Builders Workshop 14 Jul 04, 2016 12:49 PM
Question Gluing in servo tray Swasimoto Sailplane Talk 5 Jun 15, 2016 10:21 PM
Discussion Gluing magnet back into my 32-3 ? nigel99 Electric Heli Talk 15 Sep 01, 2007 06:23 AM
Help! magnet spacer glued into can on gb v1.1 Don McGill Electric Motor Design and Construction 16 Aug 02, 2006 03:21 PM
