Apr 09, 2018, 09:03 AM
r/cdawg's Avatar
My flying buddy Dale was at the free indoor flying at the Toledo Show and mentioned that there were about a half dozen Quasars in attendance. I found a couple pictures in the thread and thought I would post them here.
Apr 09, 2018, 12:47 PM
flyin' fool
goldguy's Avatar
Seems to me you have a 'hit' on your hands.
Be prepared, I've had people ask me to autograph their NutBalls.
Apr 10, 2018, 06:24 AM
Squall's Avatar
Mine's the white, blue and black checkered one! Lot's of fun. I did have a few people comment on how well it flew. Steered them to WMPF.
Apr 10, 2018, 07:22 AM
r/cdawg's Avatar
I'm sure Greg appreciated your doing that.
Apr 11, 2018, 04:17 AM
davereap's Avatar
v1 quasar flt 3 battery good (2 min 47 sec)
this the V1 with the QX motor and an 8x4.3SF prop.
unfortunately I forgot to turn the camera back on for the v2 flight.
Apr 11, 2018, 07:45 AM
r/cdawg's Avatar
You guys play rough. Between the floor, rafters and other aircraft you are definitely giving the Quasar a good durability test.
Apr 11, 2018, 09:37 AM
davereap's Avatar
When I say bash and crash, I really mean it...lol... plus it gets very cold in the hall, so any impact and the props will shatter.. the steel roof supports are killers, and seem like they could do with being higher.... the very hard concrete flooring gets hit after we manage a mid air mix up..
The 8mm thick EPP models hold up well, they bounce, small or thinner stuff can get chopped, but its not deliberate, and its all glued back together for the next time....
Last week there wasnt so many flying.. sometimes its just a madhouse 10 or 12 models up.. but its always fun..
I am thinking now of a bigger Q.. a 26" span using the QX motor, and made from the lightweight B&Q Diall 5mm green foam board.. this one just for outside .. and made a KFm2 with laminating film for extra stiffening.. It should end up at a lower wing loading.. we will see..
edit ...the big Q is being built.. but Ive gone with a KFm4 wing..using a 5mm step layer on top and a 3mm below..
The fuzz is double thickness, as is the rudder.
Apr 13, 2018, 02:11 AM
davereap's Avatar
Another session flown and again the video of the v2 was messed up , the headcam was set too high and the model was often missed, low out of frame..
another job ...to hot glue the headcam mount so its always set correctly.
However both models are flying alike.. and flying very nicely...their only noticed difference being thrust.. the QX motor with an 8x4 on 2s gives less thrust than the 2205-? with an 8x4.3sf prop..
I will experiment with better props for the QX, .. however its good enough, it does have vertical, just not so much as the 2205 with a sf prop.
The 26" is coming along... the wing was made as a KFm4, it has a total thickness of 13mm.. From the front , back to the steps, it will get a lamination film covering.. the elevons will get fully covered and will be hinged with film ..
Working today the airframe is all done and the bare frame weighs 5.6oz.. the wing is lovely and stiff, feels strong..
edit ... All done the AUW is 10.8oz with the QX motor, 3x htx500 servos, an 18A ESC , an orange RX and a 450 3s lipo..... at 3.3sqft that's a loading of 3.27ozsqft.....No Wheels however....
hopefully the specs on the QX are accurate, I should have better than a 2:1 power to weight...
I still need to add some decor, some coloured tape will do it fine
My v1 is flying lovely indoors at 3.47ozsqft.. 8oz
Apr 13, 2018, 04:04 PM
pull up -- PULL UP!!!
So here's a little powerhouse I just found: Sunnysky R2304/1800kv
https://www.tomtop.com/p-rm9293.html
They claim 20 grams, same as the 2204, but thrust into the 600's on 2S and 900's on 3S. 20 amps and 218 watts.
Wow, if true. Gotta try one.
Apr 15, 2018, 04:20 AM
davereap's Avatar
all done...
The qx motor hovers the model at 55% power.. so there is plenty in reserve..
The HXT500 servos are crap brand new they are noisy and jerky, they may need replacing..
my best small servos are tgy1440a from hobbyking, cheap, smooth and quiet.. Ive got a load of them, but wanted a larger servo for the bigger model..
edit.... now added some wheels on a 3mm CF X and axel setup..the new AUW is 11.5oz..... a 3.4747ozsqft loading, the same as my v1
Apr 15, 2018, 12:59 PM
It seemed like a good idea!!!!
Hookit's Avatar
Hi Dave, my HXT500's are rubish as well where do you get the tgy 1440a? Are they HK?
Apr 16, 2018, 12:38 AM
davereap's Avatar
yes... hobbyking... the 1440a is a lot smaller servo, but with better specs.. they are fine on the standard size Q....and have proved reliable ..
I have a lot of these..
https://hobbyking.com/en_us/turnigyt...0sec-4-4g.html
I have just ordered some of these cheap ones.
https://hobbyking.com/en_us/turnigy-...-08sec-6g.html much cheaper with a touch more strength..
Apr 16, 2018, 01:54 PM
Hookit's Avatar
Thanks Dave, my HXT's have been bloody awful !
I will try some of those as I do some smaller lighter builds.
Apr 16, 2018, 09:06 PM
flyin' fool
goldguy's Avatar
I've tried them all and have settled on this servo as being the very best micro on the market , EVER ..................
https://hobbyking.com/en_us/turnigyt...___store=en_us
Apr 16, 2018, 11:21 PM
The problem with buying HobbyKing servos, isn't the servos. HK is about the most tone-deaf, incompetent retailer I've ever done business with. Unfortunately they sell stuff I like.
I was able to buy those servos off Amazon. They still come from HK, but at least I didn't have to deal with that horrible website. I think shipping was less too.
Idea 3D-Delta, 3d epp KF delta jet, *VIDEO* *PLANS* leadfeather Foamies (Scratchbuilt) 616 Jan 17, 2018 09:09 AM
Discussion HobbyKing Shining 3D EPP 990mm PeterDale 3D Foamies 5 Oct 19, 2015 04:27 AM
Discussion Best EPP 3D With 600-1200mm Wingspan ignernt_dweeb 3D Foamies 23 Sep 23, 2015 06:52 PM
Discussion CRASH...Need Opinions on the Quasar Lightweight 3D Biplane Flyer 2MuchAir Electric Plane Talk 10 Mar 09, 2006 09:57 AM
Quasar 3D biplane from hobby lobby hotairflyer 3D Flying 95 Feb 24, 2006 08:12 AM
