Oct 09, 2017, 12:06 AM
→ 404 Not Found
Justapoke's Avatar
New Product
Mirarobot S60 Micro FPV Racing Drone - Acro - CM275T 5.8G 720P
New interesting looking product..
Not sure what to think yet, 615 motors, speed up to 20km/h and 120m distance with a 90x75mm whoop!
Mirarobot S60 Micro FPV Racing Drone Quadcopter Acro Flight Mode Switch with CM275T 5.8G 720P Camera
https://www.banggood.com/Mirarobot-S...p-1209375.html
Features:
- It can be switch 3-axis and 6-axis control modes (3-axis - Angle Self-stabilizing flight mode, 6-axis - Semi-stable flight mode), and 3-axis Mode is suitable for professional traversing fans. The 6-axis Mode is suitable for the novice user.
- The new generation of 2.4GHz two-way remote controller has a great improvement in accuracy and distance, maximum distance reaches 120m.
- Low voltage alarm feel at ease while flying.
- If the receiver does not receive the signal for 2sec, it will gradually reduce the throttle value until 1080.
- The remote control support low-voltage prompt.(Transmitter beeps under 2.9V. Return to Low-voltage condition over 2.95V.)
Package Included:
1 x S60 FPV Racing Quadcopter
1 x Remote Control
1 x 3.7V 200mAh Lipo Battery
3 x AA Battery
4 x Propeller
1 x USB Charging Cable
1 x User Manual
Oct 09, 2017, 12:16 AM
→ 404 Not Found
Justapoke's Avatar
Reserved
Oct 09, 2017, 02:59 AM
→ 404 Not Found
Justapoke's Avatar
Some more specs:
Size 90x75x30mm
Weight(Battery included) 27g
Motor hollow-cup 615
Battery 3.7V 200mah
Flight Time 5mins
Charging Time 30mins
Maximum Tilt Angle 30°
Camera:
Product Name CM275T (25mw)
Modulation FM
Channels 48
Maximum signal distance 150m
Lens H: 120°
V: 100°
Image resolution PAL: 720*540
NTSC: 640*480
Camera Standard NTSC/PAL
Operating Frequency 5645-5945MHz
Frequency Control PLL
Frequency Stability +/- 100KHz(Typ.)
Frequency Accuracy +/- 200KHz(Typ.)
Transmitter Power 14+/-1dBm
Antenna Port 50Ω
Power dissipation [email protected]
Operating Voltage 2.9V-5.5V
Highest Harmonic -50dBm
Size 14.5*12*9.22mm
Weight 4.1g
[toy] Remote:
Battery AA*3
Operating Frequency 2405MHZ-2475MHZ
Max Transmitter Power 4.5dBm
Control Distance 120m
Oct 09, 2017, 03:22 AM
Fan of just about anything RC
SoloProFan's Avatar
Clean looking frame. Now for some camera uptilt and a BF compatible FC, and it will be even better.
Latest blog entry: For the love of the hobby!
Oct 09, 2017, 04:00 AM
→ 404 Not Found
Justapoke's Avatar
And a lower price maybe!
Not sure what to think of it yet, and / or if this will become populair.
Oct 09, 2017, 04:22 AM
Back after a few years no RC..
Good looking frame but after flying E011 and Bwhoop pro with 7mm motors for fpv I would not go back to 6mm motors.....
Oct 09, 2017, 11:50 AM
→ 404 Not Found
Justapoke's Avatar
Yeah the E011 and B03 Pro are still as good as it gets at the moment, but I also still I love the E010 because of the lower weight and slower / more precise flight.
So there's still a place for 6mm indoor whoops.
But with the 27gram weight on the Mirarobot it will be the question how it performs.
And I sure won't be the first to find out.. as I fly mode-1. Will all depend on the used protocol if it's interesting in the end. At this pricepoint I'm also not seeing me taking the trouble and risk on modding another tx again.
It has to have cheap replacement parts to start with, if this will become an interesting thing to mod. With the cheap prices of the E010 / E011 / B-03 it's a no brainer to simply buy another one, but at 50 / 60 bucks I don't see a lot people doing that.
Oct 09, 2017, 01:35 PM
Merch's Avatar
The price might come down,no mention of the VTX power or am i missing it?
Oct 09, 2017, 01:55 PM
→ 404 Not Found
Justapoke's Avatar
It seems like just a regular CMT275T so 25mw is what it must be.
Any higher on a 200mAh battery and it will reduce flightime way to fast.
Oct 09, 2017, 02:00 PM
Merch's Avatar
Ah i see now,thanks i missed that bit
Oct 11, 2017, 12:07 PM
→ 404 Not Found
Justapoke's Avatar
As the CMT275T is around 25 bucks at the moment, the price might not be that bad.
That is if it is a good quad. If it has a good quality board that can be used with other Tx's, flys great and it turns out the frame is basicly indestructive, than it will be a good deal.
Still plenty of same size and quality cams around for a lot less.
Nov 06, 2017, 06:43 AM
→ 404 Not Found
Justapoke's Avatar
Yeah I also recieved the preorder notis email today.
It's also available at Gearbest now without transmitter: https://www.gearbest.com/rc-quadcopters/pp_1041575.html?lkid=11795245
Nov 25, 2017, 12:21 AM
My review of this Mirarobot S60 Micro FPV "racer"
Hi fellow rc pilots & enthusiasts
My Mirarobot S60 5.8ghz Micro FPV “racer” review includes unboxing, features, indoor, night, day, acro flights, fpv views and issues / problems experienced at the end.
Mirarobot S60 5.8ghz Micro FPV racer review (17 min 29 sec)
Dec 29, 2017, 08:11 PM
→ 404 Not Found
Justapoke's Avatar
Nice vid mate!
Discussion FuriBee X140 140mm Micro Brushless FPV Racing Drone 5.8G FPV 600TVL CC wishawhunk Micro Multirotor Drones 353 Aug 25, 2019 04:52 PM
New Product GT T901F 5.8G 720P Camera FPV Flying Spiders Drone Squirrels Mini Multirotor Drones 27 Sep 28, 2017 09:25 PM
New Product (Updating)Hubsan X4 H502S 5.8G FPV &X4 H502E With 720P HD Quadcopter GPS RTF BG Well Mini Multirotor Drones 129 Feb 19, 2017 09:17 AM
Discussion Smart Drone SMD Red Arrow Racing 5.8G FPV 720P Camera 2.4G 8CH RC Quadcopter GeekBuying Geekbuying.com 0 Oct 18, 2016 05:17 AM
