Programming YEP 90 amp ESC/BEC - RC Groups
Oct 08, 2017, 10:42 AM
I just purchased a YEP 90 ESC from Hobby King and I'm confused by the two leads coming from the ESC. I don't want to use the BEC feature, so first I want to know how to disable it. Second, it looks like the lead that plugs into the throttle channel has the coil. My guess this is the lead that plugs into the programming card (minus the red wire). Now, what is the second lead coming from the ESC for and can it be unused if I power the programming card with my radio battery? Any help would be appreciated.
Oct 08, 2017, 04:05 PM
I am a nice guy! Really!
A link to your actual ESC would be good. The Hobby King search does not yield anything with two leads as you describe.
Latest blog entry: A123 battery source
Oct 08, 2017, 04:21 PM
Mike, here's the link with two views of the controller. https://hobbyking.com/en_us/yep-90a-...able-sbec.html The two leads are visible on the second picture.
Oct 08, 2017, 05:31 PM
I think I have it programmed now. I have no idea why HK or YEP ship their controllers without instructions. Thanks Mike.
Oct 08, 2017, 11:39 PM
They do have manuals in that listing under the "Upload Files" tab.
Nov 06, 2017, 01:48 PM
Nico Peursum's Avatar
They do, however in this case it is written in german ...
What I understand is that both cables have the same function, with one as master and the other as slave. Probably for use in models with two receivers.
Discussion YEP 30 amp ESC programming teamhairball Power Systems 22 Dec 09, 2017 10:45 AM
Question 10s Scorpion OR w/ETTI HV Opto ESC & DIMENSION ENG. VHV BEC programing K.R.Joye Power Systems 0 Jun 22, 2017 10:19 AM
Help! ESC - YEP Program Card setup Jazzbari Electric Plane Talk 10 Feb 09, 2017 03:29 PM
Mini-HowTo YEP ESC Programming Info LSF226 HobbyKing 1 Jan 11, 2017 03:01 PM
Discussion YEP 80a ESC fried with programming card expohl Electric Heli Talk 1 May 21, 2016 03:57 AM
