Oct 07, 2017, 07:31 PM
Eflite 60-120 95 degree Rotating Retracts
I bent the stock wire strut in one landing. I took the wire strut out from the retract to fix it.
The coil spring came off from the collar and retract. Now the wheel would not fully rotated when the retract goes up.
I think I have not assembled the coil spring in the right way.
I appreciate it if someone can advise me.
Thanks in advance.
Oct 11, 2017, 07:15 AM
Cougar429's Avatar
Can you post a pic or two?
Familiar with their straight setups, not the rotating versions.
Oct 08, 2018, 07:11 PM
Thanks in advance.
Did you get this repaired? I just had the same thing happen to me and figured it out. Let me know if you need the details.
Oct 08, 2018, 08:16 PM
Cougar429's Avatar
Posting pics always helps.
Discussion Eflite 60-120 retracts lil hoss Flight Accessories 5 Aug 12, 2017 07:29 AM
Discussion Elite 60-120 95 degree rotator retracts edwin1 Fuel Plane Talk 4 May 18, 2015 06:27 PM
Discussion Struts for eFlite 60-120 retracts? DominicM Electric Ducted Fan Jet Talk 16 Nov 01, 2011 05:28 PM
Discussion 5mm wire and EFlite 60-120 elec. retracts sam51401 Scale Kit/Scratch Built 5 Oct 03, 2011 05:20 PM
Idea EFlite 60-120 ele. retracts mounting change. SUCCESS!!!!! sam51401 Scale Kit/Scratch Built 6 Sep 30, 2011 10:33 AM
