Vac bagging tubing - RC Groups
Oct 07, 2017, 04:33 AM
Slow builder
_AL_'s Avatar
Vac bagging tubing
I'm setting up my first Vac Bag setup.
What flexible tubing will work that won't collapse under vacuum?
Thanks.
Al
Oct 07, 2017, 07:36 AM
Hi I use the thin black retic tubing from Bunnings..
cheers
Ian
Oct 07, 2017, 08:06 AM
Slow builder
_AL_'s Avatar
Thanks Ian.
Are you talking about the stuff used for drip watering systems?
Al
Oct 07, 2017, 11:05 PM
by ZIPPER
ZIPPER's Avatar
hi Al
I have some 2mt lengths of vac bag tube you can have.
Oct 08, 2017, 02:12 AM
Entropy is happening!
Jim.Thompson's Avatar
Hi Al,
I use the cheap, generic, ubiquitous, vinyl tubing of various diameters for vac bagging. Found in any hardware store worth it's salt.
It never collapses.
Nothing special.
Also, I have used this successfully for vacuum resin infusion which requires as near absolute vacuum as one can achieve.
Oct 09, 2017, 12:09 AM
Slow builder
_AL_'s Avatar
Thanks guys.
Glen, you have a PM.
Al
Oct 22, 2017, 05:21 AM
Have Wings, will Fly!
dont's Avatar
standard 6mm air line and fittings always works a treat
Oct 24, 2017, 07:15 PM
myday.. myday
LA8PV's Avatar
Standard water hose I get from the hardware store in the "boat" section is pretty solid and stiff, I prefer to use a vacuum hose from the "car" section - it is thicker but in rubber so it's more flexible. I use a brass tube in the end (in to the bag) to prevent it from closing. Proper composites tubing is really stiff inflexible plastic but I prefer what I get from the local hardware store if it works alright.
Oct 24, 2017, 07:25 PM
Originally Posted by LA8PV
.................................... I prefer what I get from the local hardware store if it works alright.
Yes, me too! As I said above, I use the generic clear vinyl tubing. Just repeating, I have pulled this type down to near absolute vacuum (29.xxxx inches) without it collapsing.
The cylindrical shape prevents collapse under vacuum.
You may be overthinking this Al.
I am inclined to to do the same sometimes!
Oct 24, 2017, 10:16 PM
Slow builder
_AL_'s Avatar
I couldn't get the clear tube in 4mm to fit the vac meter but managed to get something similar which should work.
I'm currently working my 15th 12+ hour day straight so no progress.
Planning Friday,Sat,Sun off so hopefully I'll grt a bit done then.
Al
Discussion Fridge pump to Vac bag wiring _AL_ Composites Fabrication 9 May 02, 2017 09:13 PM
Discussion Fuselage mold vac bagging. Tim Harbour Composites Fabrication 9 Oct 21, 2016 02:43 AM
Discussion Molded / Vac Solid Core Bagged DLG wings Advice needed Chuchuf Composites Fabrication 40 Mar 04, 2016 08:06 AM
Vac bagging setup for multiple bags BillO Composites Fabrication 14 Apr 05, 2005 04:31 PM
Hot to get vac bag to hold vac. joelontheroad The Builders Workshop 3 Oct 21, 2003 08:58 AM
