Oct 07, 2017, 08:53 AM
Really nice, is this a kit or are you doing a scratch build?
Oct 07, 2017, 07:06 PM
Tempest's Avatar
Is this the old George Miller design? Looks good.
Paul
Oct 07, 2017, 07:40 PM
deltas are cool
AIR SALLY's Avatar
Going to be a big one!
Oct 08, 2017, 01:03 AM
hello , I had general plans, I've been working on drawings for laser cut and , and assembly drawing. Also, I made changes in the connections of parts. I designed the pieces to be interlocking .
Oct 08, 2017, 01:09 AM
Paul
Yes George Miller design.
Oct 08, 2017, 03:22 PM
Calm before the storm
Flyboy81's Avatar
Really interesting build here. A-10 is a fun plane to fly. Lots of room for batteries in this bird!
Nov 02, 2017, 07:00 PM
LordZ1978's Avatar
Nice plane.
This bird will be gigantic.
Best rgds
Nov 04, 2017, 12:00 AM
Lets burn
I've just completed this plan. I got it lazer cut here in Aust.
Ive used jet fan 110mm fans and HET motors, yep 120 amp esc. Got 12 s each side, producing 7 kg thrust each at 90 amps.
Its heavy, 15 kg, but flys very well. Used Georges c of g, a tiny bit nose heavy. Not much tho. Also made removable panels on nose, to service rx batts, removable panel over the wing to edge of canopy for flt batt access.
Any questions please ask. This was not a strait forward build, I also modded the wings, so outter panels removable.
Matt
Nov 04, 2017, 12:05 AM
Lets burn
Some pics
Nov 04, 2017, 12:24 AM
4stripes's Avatar
Nice work Cosmo! Must be nice to see and hear in the air. What is the span?
Nov 04, 2017, 12:34 AM
Lets burn
Its 85 inch wing, very very cool plane. Any info, just ask. I built this basically without much knowledge of the jets performance ect. So I can steer you in the right direction for success.
But it all worked out well. 100s of hours work.
Matt
Nov 08, 2017, 12:05 AM
Cosmo21, It has been incredibly beautiful, I hope I can finish it.
Nov 08, 2017, 08:07 AM
world's slowest builder
Air-Jon's Avatar
Wow! Incredible build Cosmo. You did not miss a single detail! The small Skymaster A-10 comes out to nearly the same weight so i say you did well!
Is that an Avonds F-16 in the backround?
Discussion Yellow Aircraft Stingray 90 or 120 mm EDF Scarey Electric Ducted Fan Jet Talk 101 Jul 24, 2013 11:35 AM
Discussion Lets design a 120 MM EDF @ 10lbs..........cheap hobbies Electric Ducted Fan Jet Talk 42 Dec 09, 2009 11:16 AM
Discussion New SkyMaster Viper Jet 120 mm EDF Ron101 Electric Ducted Fan Jet Talk 23 Nov 03, 2009 04:56 PM
Discussion AP 120 mm EDF w/ Scorpian outrunner Any thoughts? Scarey Electric Ducted Fan Jet Talk 6 Nov 14, 2008 09:47 AM
Discussion 120 mm EDF A-10 Warthog eatond Castle Creations 0 Apr 01, 2008 01:34 PM
