Paperwork for 70'ish Fox 40 CL Engine - RC Groups
Oct 06, 2017, 10:09 PM
Now I have to land that thing?
PGregory's Avatar
I was gifted a nice Fox 40 plain-bearing CL engine by a generous club member.
It came in the box, nice, but no paperwork.
Does anyone have this to scan and send me ? Much appreciated, if so.
I believe you would want to go up on the prop from a .35, to a 11x5 or 11x6.
Almost no info on the internet, at least that I have found.
Oct 07, 2017, 09:50 AM
Old Timer
The Kiwi's Avatar
The one that I have is also unused, and I never had the instructions, either. Duke had the original design several years before modifying it and selling a few of them. Initially, it was intended to be a racing engine, for CL Rat Racing. George Aldrich designed it, he told me.
George designed it with twin ball bearings on the crankshaft. It is a Schneurle ported type, with an unusual mounting pattern. A few European stunt fliers used the type, but generally, the engine wasn't well accepted here in the US. Similar to most engines ported like that, it will run best in a steady, higher-rpm state, with a lower-pitched prop.
An 11-5 is more suitable to a slower-running plain loop-scavenged engine in the 35 size. You'll need an 11-4, instead.
Oct 11, 2017, 11:53 AM
flyelectcl's Avatar
This may be of help
Oct 11, 2017, 11:58 AM
I believe this version is a collaboration between Duke Fox and George Aldrich. The liner uses a laminar flow transfer port.
Oct 11, 2017, 12:24 PM
Old Timer
The Kiwi's Avatar
Originally Posted by flyelectcl
That ("Rocket") 40 predated the OP version by 12-13 years, and was closely related to the the several Combat Special 35s of 1955, 1957, and 1960., as well as to the several "Rocket 35" sport engines.
Discussion SPEEDSTER 78/40/26/20"+ 3.0/4,8M+ FOX 40/70"+ SWIFT S1 glider build. SpeedsterDEN Slope 421 Jul 22, 2017 12:49 PM
Discussion New Fox .15 BB for CL army_eod Engines 8 Oct 24, 2014 11:29 AM
Question Smoke system for a .40 sport plane (.70 4-stroke engine) N410DC Flight Accessories 5 Oct 18, 2014 07:28 AM
Discussion 70's type CL plane for kids, made now? bsoder Control Line 49 Jul 20, 2011 02:20 PM
Discussion Any plans for more 40"ish sized birds? Tram GWS (Grand Wing Servo) 3 Oct 09, 2007 06:43 PM
