Oct 06, 2017, 08:34 PM
Question
FlySky Fs-IA6B Receiver
Hello there,
I started to build my first quadcopter. I'm using Pixhawk 2. I bought FlySky FS-i6 as a transmitter. It also includes FS-IA6B as a receiver. My question is very simple, how i wire this receiver to my pixhawk. I know FS-IA6B has ppm output. But the receiver package only includes antennas and bind plug. So how can i connect FS-IA6B to pixhawk 2 ? Should i have to buy any thing?
Thank you for your answers, and sorry for my stupid question
Oct 13, 2017, 05:33 AM
@mbasaran95
Connection is simple, for PPM use pins marked with red.
But better option is using SBUS - use my fw for I6 change output mode to PPM/SBUS and use IBUS port acting as SBUS.
Apr 09, 2018, 01:25 PM
@qba 667
"use my fw for I6"- can you please explain it a bit more ?
Thanks in advance....
Apr 12, 2018, 02:56 AM
@qba667 in factory I6, you can not force SBUS, using firmware I have improved it is possible.
https://github.com/qba667/FlySkyI6
Sep 17, 2018, 04:54 AM
Hi,can you explain how to do it, i flashed your firmware, but the setup is not evident?
Also, i do not understand why in ppm , ch6 is "used" and so not availlable...i noticed that in MP , its moving with Ch5.
Thank you
Sep 17, 2018, 09:00 AM
@francoisphil in settings of I6 you can select output mode PWM/PPM IBUS/SBUS.
Check firmware wiki page.
Channel 6 is used because you have selected HELI as model type check here:
https://github.com/benb0jangles/FlyS...Mod-/issues/64
Sep 17, 2018, 06:45 PM
Thank you for your fast answer,everything working fine, now , i have 10ch in s_bus and 8 in PPPM
Thanks again
Sep 18, 2018, 04:29 AM
new problem
I had to go back to PPM , for some reason, so i get back my 8 channels working , but when i switch off the transmitter , all my Radio IN in Mission Planner /Failsafe go to Zero, i checked with a scope , there is still signal delivered by the receiver, something i am missing?
Hi, what i have discovered , is that with your modification , Ch7 and 8 , become very short , when TX is OFF, then the Pixhawk does not acknowledge the PPM signal anymore, so how to setup my fail-safe ?
Sep 20, 2018, 09:30 AM
@francoisphil the fail-safe configuration for those 2 channels must be added, I have to find free time to do it, I think there is already issue listen on github.
Jul 24, 2019, 09:51 AM
Can anyone explain me what the 2 cables coming out of receiver are actually meant by..?🙃🙃
Nov 10, 2019, 07:55 AM
Ibus/Sbus
Hello all...
I am connecting an FS-ia6b receiver to a flight controller that does not work with Ibus. It needs PWM or Sbus. I have not seen anything saying this receiver works with Sbus. But, according to the label on the receiver, there is an Sbus connector. So, for grins, I connected the Sbus output on the receiver to the Sbus input on the flight controller, set the transmitter (Taranis QX7) to use sbus, and it works. So, is this receiver Sbus capable, or am I just totally confused?
Thank you for your time.
Ed
Update... I thought the FS-IA6b and the Turnigy TGY-IA6B were identical, but maybe not. I see the TGY is advertised and labelled as being SBus capable, but the FS version is not. I am using the TGY version (incorrectly stated above). Possibly flashing the FS receiver with the TGY firmware will light up SBus on the FS version. I have a box full of spare FS version receivers, so I may chase this down that road. It would be good, for me, to be able to use SBus on these. Maybe the FS version is already Sbus capable, and not documented. That's easy enough to tell, just by trying one.
Sorry for the confusion. It's too early.
Nov 10, 2019, 06:09 PM
Now I'm befuddled. I connected a Flysky FS-IA6B receiver (Ibus) to the Sbus port on my flight controller, and it worked. The flight controller does not support Ibus, and the transmitter was configured to use Sbus. So, does this mean the FS-IA6B does support Sbus? Is the receiver output dependent on how the transmitter is set up (Ibus or Sbus)? I'm not clear on just what the difference is between Sbus and Ibus. I don't want to see my plane corkscrewing straight down at 100 mph because of some subtle, but important difference between the two protocols. That would ruin my day.
Is anyone able so shed any light on this FS-IA6B on Sbus mystery? The Turnigy TGY-IA6B works fine, and is labelled as Sbus compatible.
Ed
Dec 08, 2019, 09:20 AM
Ed
I used IA6B on ibus pins to Sbus on pixhawk 4 FC for long time. Never had problems.
Dec 08, 2019, 05:14 PM
Yes. I found this receiver (and the Turnigy TGY-IA6B) can run Ibus or Sbus, depending on the transmitter being set accordingly.
Thank you for the confirmation.
Ed
Question FlySky Fs-IA6B Receiver mbasaran95 Radios 0 Oct 06, 2017 08:19 PM
Discussion Help Binding TH9X and Flysky FS-ia6B receiver SenorJez Beginner Multirotor Drones 5 Aug 18, 2017 10:04 AM
Discussion Flysky FS IA6B receiver only powers on when connected to Cleanflight. Ship79 Multirotor Drone Electronics 2 Dec 25, 2016 12:38 PM
