LaForge V2 Fatshark Module - V3 Firmware
The LaForge V2 Pro is a 5.8GHz receiver module with OLED display and a ton of features that will change the way you FPV.
The LaForge V2 Pro
The LaForge V2 Pro was designed exclusively for the Fat Shark module bay. With this main module you will immediately have the power to quickly tune into your crafts channel, or scan the spectrum to find a free channel. Add the diversity module for an even more reliable FPV experience.
What's in the box?
  • 1x LaForge Main Module v3
  • 1x Main Module Molded door
  • 1x 90 SMA
Features
  • Save Channel - Startup with last saved channel and settings.
  • Screen Saver - Display current channel, call sign, and signal strength.
  • Settings Menu - Calibrate RSSI, set call sign, frequency order, save.
  • Quick Save - Hold select for 2 seconds in manual mode & Search Mode.
  • Status LEDs - Indicates power, status, and active antenna.
  • IR Emitter - Quickly bind to the LaForge Pro module. (Recommended as a backup source for pro module. IR Remote is the preferred method)Quickly bind to the LaForge Pro module.
  • Three Button navigation - Up, down, select.
  • Manual Mode - Set channel manually.
  • Search Mode - Search next channel based on signal strength.
  • Scanner - *Scan spectrum of all 40 channels.
  • Clean Power - Large 470uf tantalum capacitor.
  • Dual Antenna Filter
Channel Mappings
  • 5865 - 5845 - 5825 - 5805 - 5785 - 5765 - 5745 - 5725 - Band A
  • 5733 - 5752 - 5771 - 5790 - 5809 - 5828 - 5847 - 5866 - Band B
  • 5705 - 5685 - 5665 - 5645 - 5885 - 5905 - 5925 - 5945 - Band E
  • 5740 - 5760 - 5780 - 5800 - 5820 - 5840 - 5860 - 5880 - Band F / Airwave
  • 5658 - 5695 - 5732 - 5769 - 5806 - 5843 - 5880 - 5917 - Band C / Raceband
Learn More and Order
Head over to our friends at ReadyMadeRC for more info.
Rant Fatshark goggles and the laforge modules cobra93 FPV Equipment 10 Jun 08, 2017 05:49 PM
Discussion Latest (V2 901 V3.3) FreeX firmware - HERE! faceplant FreeX SkyView Quad Copters 27 Dec 04, 2015 03:21 PM
Question Difference between firmware v2 and v3 on microbeast? getsuyoubi Electric Heli Talk 0 Jan 15, 2015 02:45 PM
Alert Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) tallflyer Electric Plane Talk 32 May 24, 2014 11:12 PM
