Oct 27, 2017, 03:45 PM
Team OpenAVRc
Bracame's Avatar
Import - Export Menu
Hi,
In the latest release you could find in the simulator a "input - output" in File menu
His role is to convert eeprom from one format to another one (4k M2560 to 10K F-Ram or revert it, the 30 to 60 models will be lost)
How to :
-> Save your transmitter eeprom with Desktop.
-> Load this eeprom file in Simulator, run it . When Main task is running, you can export your eeprom to text file : Export to "Myeeprom.TXT".
-> Open the other simulator (Stock or F-Ram), run it .. do calibration, ... When Main task is running import your "Myeeprom.TXT".
-> Save your new eeprom : It is Converted ;-) ready to load to a modded transmitter.
You could also have a look at the text file : There are a lot of fields !
This is also the way to convert to future V3.0 eeprom format witch will be not compatible OpenTX. Only 4K is compatible.
Oct 27, 2017, 04:54 PM
On page 19, of my GOOGLE TRANSLATED to english .doc file, which was found on:
https://github.com/Ingwie/OpenAVRc_D...penAVRc_V1.doc
shows me a screen, with a WINDOWS command prompt executing some batch file, using "MAKE CLEAN". Until today, I was under the impression that "MAKE CLEAN" was a LINUX command. My version of WINDOWS definately does NOT have a MAKE command, is this a special french version of windows? What other software must I install in order for this part of the procedure to work?
Oct 27, 2017, 05:31 PM
Team OpenAVRc
Bracame's Avatar
HI, or Hello ?
Did you install the setup file on windows ?
Yes it is Linux command, If you use only Linux, I propose you to build a virtual PC using virtual box (with windows).
I've modded some files Work from XP to Win10
Sorry, I love Linux but to please to the bigger part of the end user, we develop windows application.
Install and try the setup (It is clean and does not install files anywhere) .
This is the simply way to watch this "miracle"
Edit : Latest Setup file : https://github.com/Ingwie/OpenAVRc_D...M.exe?raw=true
Tell us if there is a problem ....
Oct 29, 2017, 02:53 PM
I just use wine...
corrected 2 min later:
Wow now it is not working) Yesterday I played a bit with simulator...
Oct 29, 2017, 03:32 PM
Originally Posted by Ievgen
I just use wine...
This is an ATMEGA 2560 application. In the past, I load them in Arduino IDE, compile an .INO and I'm done. Complex projects for me use Visual Studio, I write myself and my own libraries for. Is there a way I can just compile this from Visual Studio - does anyone know?
Load wine, or a virtual platform, with linux - to install and configure the 125+ pre-requisites is way too complicated just to compile an ATMEGA 2560 .hex file.
Oct 29, 2017, 04:27 PM
Team OpenAVRc
Bracame's Avatar
Hi,
Does Visual Studio accept AVR-GCC and makefile ?
Simple solution to compile AVR code on Linux : Install AVR-GCC, copy source files to a directory , open a shell in this directory and type Make with the correct options.
Oct 29, 2017, 09:50 PM
Hi,
Ok I am familiar with linux, and have done make clean installs before. Up until now, I did them and whatever goes on compiled the code to be run on the actual linux platform I was running.
So, the magic part of this would be the avr-gcc? I really got confused with the procedures that explain to install Visual Studio - since I would obviously need a windows platform for Studio. I can't see anyone flip-flopping between two computers with different operating systems to compile a .hex every time they wanted to test it.
Oct 30, 2017, 06:18 AM
Team OpenAVRc
Bracame's Avatar
... I really got confused with the procedures that explain to install Visual Studio.....
What procedure ?
The setup.exe install the compilation tools, OpenAVRC Desktop and Simulator apps + the sources files.
Those give to the user ability to compile the firmware whit there preferred options (by check box, etc ..) , does the download/upload(flash, eeprom, F-Ram),
And a simu to program models at home witch can convert eeprom format.
Oct 30, 2017, 09:12 PM
What procedure ?
The procedures in the document, page #19:
Is this the correct procedure to compile a .hex file, from the source code?
Oct 31, 2017, 09:23 AM
Team OpenAVRc
Bracame's Avatar
Yes, This is how to do with the Desktop app.
I don't see Visual Studio mentioned
Nov 01, 2017, 02:09 AM
Hi all!
I have some stupid questions more!
In radio documentation it is mentioned that it supports up to 16 channels, and it is quite enough for almost any model. So what are those? First 4 channels are AETR - sticks, then we have 3 pots, 2 rotary encoders (though 1 of them is may be used for the menu purposes) and 7 switches - am I right?
Second question is concerning OpenAVRc_V1.15_FRAM.exe It works somehow both under wine ( quite unstable) and on virtual win computer. My main system is self build Linux on *buntu 16.04 repos and its locale is UK_ua.UTF8. Virtual win systems (winxp+win7) I have are on Russian and Ukrainian respectively. In all this cases part of letter characters in the program are Cyrillic, and it doesn't really meters what language I choose - English or French...
My French is not so good itself, and this small problem makes understanding quite a challenge.
Nov 01, 2017, 02:27 PM
Team OpenAVRc
Bracame's Avatar
Hi Ievgen,
AETR is for fixed mixer. All channels are free mixed here : You can connect your motor one channel 1 or 2 or ... what you want
Look at OpenTx Open9x documentation about the mixer.
Sorry for the Cyrillic characters, It was not expected.
I can propose you to translate the windows app with Poedit : https://poedit.net/download ..Russian or Ukrainian : As you prefer.
I will send you original .pot file.
After, I will compile Russian and/ or Ukrainian simulator and add to the Setup file.
Nov 01, 2017, 02:43 PM
Ok! That is good idea! I will wait for it.
sudo apt-get install poedit - done)
Nov 01, 2017, 03:05 PM
Team OpenAVRc
Bracame's Avatar
OK, here are the files : 2 Pot (Desktop & Simu) and 2 PO (English translation to help you).
When you finish tranlation, you can compile it into a .mo file with Poedit.
Place it into the "fr" directory : OpenAVRc_Desktop.mo and OpenAVRc_Simulator.mo to test.
Hope I'm clear.
Nov 02, 2017, 09:39 PM
Houston, we have a problem. I built translation file, changed default fr file and...
part of french text is not changed :^)
Also I built English translation, and it has the same problem.
Data OwnTX / OpenTX - Displays, MCU boards etc. that work with OpenTX and similar firmware xnalpf Radios 6 Oct 26, 2018 07:55 AM
Discussion Migrate models from Taranis (OpenTx 1.?) to Taranis Plus (OpenTx 2.2.0) Mr Rowl FrSky 1 Aug 23, 2017 08:33 AM
Discussion MZ 18/24 Low Speaker Volume Solution Agustaoexfh Graupner OPENHOBBY 4 Nov 25, 2014 04:09 PM
Discussion Hillary's "solution" to mortgage crisis no solution at all... craab Life, The Universe, and Politics 17 Jan 20, 2008 12:53 PM
