Oct 06, 2017, 09:10 AM
Sagitta Fanboy
Originally Posted by Bajora
Nowwwww, lets upscale this one to an 1100-1300mm wingspan (or larger?) version too.
Love to see a 3S one in around 1.3m with flaps and a 2-2.2m one for 6S with all the toys (flaps, retracts). Maybe make one of those a Turbo Commander to cover a few bases. Got a chance to see a couple Turbo Commanders operating last month when they were bird dogging a couple fires.
Oct 06, 2017, 09:32 AM
microheli's Avatar
Originally Posted by bhoov128
What an ugly plane. I used to like UMX and then I discovered Flite Test.
Kidding.... would like to have this one
I suggest anyway add some lines and rivets like this
Oct 06, 2017, 10:44 AM
DFS#000178
Rampage's Avatar
Originally Posted by mattman0182
That price though....yikes.
Same price as the A-10. It probably uses the same board.
Oct 06, 2017, 10:55 AM
What's the story on the paint scheme, is it based on a real plane or just for visibility?
Oct 06, 2017, 11:28 AM
**I'm Battman**
RCBABBEL's Avatar
It does.
EFLAS6410NBLT
https://www.horizonhobby.com/as6410n...-eflas6410nblt
Hopefully many more UMX twins to come!
Roger
Oct 06, 2017, 02:15 PM
Are the motors/esc's on a single channel or could they be setup for thrust vectoring (or whatever it's called)
Oct 06, 2017, 02:20 PM
Lifetime Member
JohnM's Avatar
I am sure they are both on the throttle channel only.
Oct 06, 2017, 02:54 PM
Ten Minutes on a 450mAH Battery?
That is according to the Horizon Hobby site -- up to 10 minutes on a 2S 450mAH battery. Is that realistic? I'm hard pressed to get more than 7 minutes on my UMX Timber using a Nano-Tech 450mAH flying mostly low and slow. And that gives me a reading of 7.6 volts 30 seconds after landing.
Oct 06, 2017, 03:12 PM
addictedtoplanes's Avatar
Might do a Turbo conversion on this. The bird dogs used the same hanger that my flying school used, so it was really neat to see them up close.
Oct 06, 2017, 03:39 PM
I'd rather be flying!
turboparker's Avatar
They are most definitely on a single channel, as none of the conventional fixed-wing UMX bricks have dual-channel ESCs, nor do they support reverse thrust. To have differential thrust, you'd have to reprogram the brick for full 6-channel operation (they're factory-programmed for reversed CH2 on the AUX port), put a Y on the ailerons, install external ESCs on CH5 & 6, connect the motors to their respective ESCs, and then program your transmitter accordingly.
Joel
Latest blog entry: E-flite 850mm Pitts
Oct 06, 2017, 03:53 PM
Voltage is not a reliable indicator of discharge-depth. The only true measurement is how many mAh it takes to recharge. Also - flying to a rest voltage of 3.8V/cell is only ~50% discharged. The rule for LiPos is to not discharge them deeper than 80% - as measured by mAh required to recharge, divided by pack capacity. With a 450 mAh pack, 360 mAh required to recharge would be an 80% discharge.
Given the above - you're using ~32.14 mAh/minute while flying mostly low & slow with the UMX Timber. 360/32.14=11.2
So, that would be ~11.2 minutes to the actual 80% discharge point with a 450 mAh pack.
Joel
Oct 06, 2017, 04:09 PM
Lifetime Member
JohnM's Avatar
Have you tried flying for an additional 2 minutes and then check the resting voltage (after 30 seconds)? If so what was it?
Oct 06, 2017, 06:25 PM
DFS#000178
Rampage's Avatar
Has anyone (probably in the A-10) flown 3S on this board?
I have a bunch of 3S 500s. I'm wondering how hilarious that would be. Probably just hilarious enough to blow the blue smoke out..
Oct 06, 2017, 07:28 PM
Acft Attn Deficit Disorder
Cubcrazy's Avatar
I doubt anyone would fly 3S on the A-10, but this Commander is a simple matter of just re-propping , or swapping motor like everyone does in all the other UMX planes that routinely get the 3S overhaul. I think its the 2450kv motor swap, and or people prop down.
-CC
Latest blog entry: From the CC Paint Shop
Oct 06, 2017, 07:30 PM
Custom User Name Title
bhoov128's Avatar
I haven’t because the fans are much more unforgiving than the props.... plus the umx inrunner motors can’t take 3S.
But they should be the same escs as the rest, all of which do pretty good with 3S...
Help! BH Aero Commander Shrike EP actual cg? Sessholvlaru Scale ARF/RTF 1 Aug 14, 2017 10:28 PM
Discussion Ayres Thrush (aka Snow S-2, Aero Cmder Ag Commander & Rockwell Thrush Commander) TedD60 Scale Drawings and Three Views 1 Aug 25, 2015 10:19 AM
AERO(jet) COMMANDER Larry Dudeck Electric Ducted Fan Jet Talk 2 Oct 09, 2001 11:10 AM
Aero(jet) Commander Larry Dudeck Sport Planes 3 Sep 29, 2001 03:44 PM
AERO COMMANDER not in command Larry Dudeck Sport Planes 24 Jul 14, 2001 10:18 PM
