Dec 28, 2017, 09:01 PM
AMA xxx6793/ NAMBA 1054
rcnutrc's Avatar
Originally Posted by Tahoed
Just wait a minute, it'll land......
Yeah, I think it just landed ... 54 min. no activities on this thread.
Latest blog entry: My SlowProgress
Dec 28, 2017, 10:58 PM
Work hard, play hard
Oxotnik's Avatar
Hey, Joel, tell me again how the accelerometers in AS3X receivers work.
Dec 28, 2017, 11:18 PM
Hugo Flynow's Avatar
Originally Posted by turboparker
NO! AS3X DOES NOT USE ACCELEROMETERS! It's just a simple 3-axis gyro-based damping system. It has no idea which way is up. SAFE uses a 3-axis accelerometer to provide attitude-awareness for the autolevel flight-mode & panic button functions.
Joel
Good thing I didn't mention gremlins....
Dec 28, 2017, 11:19 PM
Custom User Name Title
bhoov128's Avatar
Honestly, I think there's a problem somewhere within the SAFE system that is causing the elevator to glitch.
Dec 28, 2017, 11:21 PM
That thing almost hit me
Tahoed's Avatar
No problem with the SAFE. I just checked and it's locked.....
Dec 28, 2017, 11:31 PM
But AC doesn't have SAFE?
Hey...what's that on my leg?
Dec 28, 2017, 11:39 PM
bhoov128's Avatar
You mean the pulling sensation?
Dec 28, 2017, 11:40 PM
Yeah....and my sock's wet.
Dec 28, 2017, 11:41 PM
Tahoed's Avatar
Better make sure that's not Dale down there....
Dec 29, 2017, 03:08 AM
Sooooo, 1; who wants to do a video showing how exactly to reprogram the little brick to get the AS3X on a switch?
2; if this glitchmageddon is down to a momentary loss of enough volts/amps to the brick because the motors are sucking too hard how about propping down slightly?? there was an issue with the GeeBee and changing to a GWS prop solved that, maybe using a couple of GWS 5030's instead of the 3 blades would help?? it isn't like there is going to be a shortage of thrust
alternatively after the model is bound drop the ATV / travel limit of top stick down to 90% ?
Dec 29, 2017, 09:04 AM
Tahoed's Avatar
How about Horizon bringing an actual Ready to Fly plane to market instead of these Ready to
Fix ones?
Dec 29, 2017, 09:51 AM
It makes me wonder...when they shoot all those videos for the HH promotion of this plane....did they have a perfectly working plane, or had to set aside 5 glitchy ones before they got a good one....just shrugged, and said.."We'll worry about that later.."
Also....I rarely flew mine WOT...so maybe that's why I observed less issues.
Then again...Ben's wasn't WOT sitting there on the ground.
Dec 29, 2017, 10:06 AM
Oxotnik's Avatar
I rarely fly mine WOT either. An occasional fast pass, or a climbing maneuver. As I'm thinking back on it, I do think that glitches occur around 1/2 to 3/4 throttle, too. I'm going to the field today. If I get it in the air today, I'll do some experimenting.
Dec 29, 2017, 10:07 AM
When you're done "experimenting", clean up and then let us know how the plane flies...
Dec 29, 2017, 10:23 AM
Tahoed's Avatar
After sitting and running several different batteries (2s and 3s) in the shop yesterday, throttle position doesn't seem to matter. The props are balanced.... Ordered the little programming gizmo yesterday and will see if I can turn off the AS3X, but I don't think it's going to fix the problem..... We will see....I have come to realize that the planes I build have none of these problems....
Help! BH Aero Commander Shrike EP actual cg? Sessholvlaru Scale ARF/RTF 1 Aug 14, 2017 10:28 PM
Discussion Ayres Thrush (aka Snow S-2, Aero Cmder Ag Commander & Rockwell Thrush Commander) TedD60 Scale Drawings and Three Views 1 Aug 25, 2015 10:19 AM
AERO(jet) COMMANDER Larry Dudeck Electric Ducted Fan Jet Talk 2 Oct 09, 2001 11:10 AM
Aero(jet) Commander Larry Dudeck Sport Planes 3 Sep 29, 2001 03:44 PM
AERO COMMANDER not in command Larry Dudeck Sport Planes 24 Jul 14, 2001 10:18 PM
