Oct 15, 2017, 11:52 PM
It's safer at 400'
azflyinghigh's Avatar
Originally Posted by Trill
Thanks for the video!
What's your set up?
Torque 4016
Hobbywing 100amp V3 esc
Savox SV-1250 servos @ 7.4v
Xoar 16x7
The only thing I am gonna do different on the V2, is Hitec HS-7245 servos instead. I have not had luck with these servos. They were fine for about 45 flights, then I bumped the bec up to 8.4. Soon after I had an aileron servo fail, replaced it. Now the elevator servo wont center well. I was really happy with them up until this point. I since have lowered the bec back down to 7.4v. Have a new elevator servo on order. Other than that, this has been a fun plane. For me it does the meanest crankshafts and knife edge spins. That might be why servos have failed. I fly this plane the most aggressive.
Oct 16, 2017, 12:40 AM
Canucklehead
Had issues with Savox 1250 in my elev too at 8.2v. The others are still going strong. But the replacement I got is hands down top notch. More power and speed than you really need ( more is mostest better) and cheaper than the Hitec too!
Latest blog entry: Little bout me
Oct 16, 2017, 09:10 AM
Now I'm a "Low Flyer"
high flyer Rich's Avatar
60" Slick V2 vs. 60" Laser
Thanks for the opinions and feedback. I just ordered the yellow 60" Slick V2 and will report back in a couple of weeks on the difference between it and the Laser.
Oct 16, 2017, 03:13 PM
Trill's Avatar
Good report
Looking forward to your report on the V2 60" Slick. Great choice on the yellow scheme!
I hope to have my V2 60" Slick trimmed and dialed in before I report to Korea on 30 October 2017.
President Trump will need to deal wisely with "Rocket man".
Oct 16, 2017, 06:15 PM
Gregertman's Avatar
Trill what branch of the military are you in? Have you been to Korea before?
Oct 16, 2017, 07:04 PM
Trill's Avatar
Retired Army
US Army, Retired
This will be my second trip to Korea as a contractor.
Thanks for asking.
Oct 16, 2017, 07:45 PM
Gregertman's Avatar
I was in the Air Force. I've been to Korea 2 times both short TDYs. I liked it there. Most likely I would be there now if I was still in. I was a B1b crew chief and my plane is there now.
Oct 16, 2017, 08:05 PM
That had to have been quite an experience! Is this the plane?
THIS IS WHY KIM JONG UN IS AFRAID OF B-1B LANCER (2 min 34 sec)
Oct 16, 2017, 08:14 PM
Gregertman's Avatar
Yep that's the one. It's much more impressive when you see one up close or hear one on a low fast pass with afterburners lit.
Oct 16, 2017, 10:09 PM
Trill's Avatar
Awesome
"Nothing can stop the US Air Force!"
My wife is former USAF.
Oct 17, 2017, 11:21 PM
Altitude is my friend...
Depronicus's Avatar
I'm really glad to have this plane. It's a beautiful piece of work. Everything fits perfectly and the overall quality of construction is remarkable. EF/3DHS must be very proud of this ARF.
Construction is coming right along. It should be flyable by this weekend.
Oct 18, 2017, 04:19 PM
Trill's Avatar
Me too
Yes, I hope to have mine in the air soon.
What do you think of the specs on the servos in the hyperlinks below?
http://www.promodeler.com/DS160CLHV Amp draw (stalled) is only 1.8 Amps per John Beech, mechanical engineer and General manager at ProModeler.
http://www.promodeler.com/DS160BLHV (This is the brushless version for less than the cost of the MKS HV9767.)
Thanks again for the specs on competing servos.
Oct 18, 2017, 05:46 PM
The Visionary Aerobat
This is a standard voltage servo setup so, if you plan on HV servos, choose an 80A esc that has a 7.4V BEC output. I use the ZTW Gecko 85A esc. Also, choose a lower KV motor so you can swing a 16" prop. Better to have that room to grow even if you primarily fly sport. I run the stock 500 kv motor. What servos are you going with?
Originally Posted by jobinseattle
I recently bought this plane and expect to get it on Wednesday. I plan on using this power setup with a 5 4500mah cell battery.
Leopard Power 4260/5T 580KV 1000 Watt Outrunner Brushless Motor
Sky Power 80A ESC with Switchmode BEC
Prop APC 14x7
I am not a 3D pilot, plan on using as a sport flyer. What do you guys think of this setup?
Oct 19, 2017, 04:45 PM
Team Extreme Flight
Doc Austin's Avatar
Baby needs a new plane. Any suggestions?
Oct 19, 2017, 06:00 PM
Trill's Avatar
V2 3DHS 60" Slick evaluation
People want your review of the
V2 3DHS 60" Slick.
Article Extreme Flight 74" Slick 580 EXP blucor basher 3D Flying 5165 Yesterday 03:32 PM
Article Extreme Flight 52" Slick 580 EXP EXTREME FLIGHT 3D Flying 4066 Jul 17, 2019 10:12 PM
Discussion Extreme Flight - 3DHS 79" Slick 580 blucor basher 3D Flying 2028 May 10, 2019 01:41 PM
Discussion 3DHS 60" Slick 580! EXTREME FLIGHT 3D Flying 1709 Sep 25, 2018 12:34 PM
Discussion 3DHS 60" Slick 580 V2 Red/White jobinseattle 3D Flying 22 Nov 23, 2017 12:27 PM
