Nov 29, 2019, 11:51 AM
Even the servo arm screws are beefier.
Promodeler on the left, standard on the right.
Only .019 but bigger is bigger.
Drilled out my MPI arms to accommodate the beef.
Dec 13, 2019, 11:28 AM
Had a transmitter malfunction. All of the sudden when I held the rudder to either side and ran the throttle up and down, the rudder would shake.
tried several planes and it did it on all of them.
Sent it in and I have it back now. Works great again.
Here is my 2S LiPo placement.
Velcro under both the R\X and pack. The zip ties are more or less just a seat belt.
Dec 13, 2019, 09:06 PM
Probably over kill, but the servo arms I bought had 4-40 threads for the linkage.
The ones provided in the kit seemed to be "Flexy" anyway.
Soooo, yeah.
I give you my elevator push rod. Plan on doing the same for the ailerons.
Dec 14, 2019, 05:42 PM
All set up and ready for maiden.
Just need some packs. I have some old 6S 3300s from 2013 but I am going to order 3700s soon.
Now I think I need the 100" big brother of this airframe.
Dec 14, 2019, 06:04 PM
I am not a robot
Sideslip's Avatar
That is one pretty airplane. I'm sure you will enjoy it a lot. But hey, treat yourself. The 74" Slick is a real honey of a plane. You could have that one in Red/White/Blue and then work your way up to the 100".
Dec 14, 2019, 06:35 PM
I love the way the plane looks also. I bought it to throw in the Tahoe to fly through the week.
74", I will always have a spot in my heart for a good 35cc plane.
However, I also have their red, white, and blue 88" Edge with a DA-70 in it. This thing is solid. Crankshafts and blenders all day!
20 years in the hobby and after flying several 35% planes, its time for one of my own.
Dec 14, 2019, 06:49 PM
I am not a robot
Sideslip's Avatar
Oh well, in that case there you go.
Dec 14, 2019, 07:21 PM
Haha! You're definitely helping me along with it!
Dec 15, 2019, 08:59 AM
PSB,
If I'm reading right and that's an 800mAh lipo, how many flights are you planning per charge? I started with a 910mAh 25C, and one flight brings it down to 4.0 per cell, which could probably stand one more flight. But I ran one more flight, and telemetry showed the voltage coming down to a min of 3.6-3.7v per cell (ending the flight at 3.9v), and I figured I was starting to push the battery with that second flight especially with crankshafts and pop tops. Nowadays I fly one flight with those 910 packs.
I added an 1100mAh 30C lipo to the mix, and that one flies two flights just fine, never dropping below 3.8v on the second flight.
F.S.
Edit: running ProModeler 160's
Dec 15, 2019, 11:01 AM
Originally Posted by Time Portal
PSB,
F.S.
It is indeed an 800. I was going to check it after one flight and see how it held up. I have the same DS160 servos in this one. Since those little LiPos were fairly inexpensive, I did pick up 4 of them as one of the fields around me lacks AC power.
Looks like I will be swapping them out every flight just as you are. No biggie at all and THANKS for the heads up!
Dec 15, 2019, 12:37 PM
A bit late to reading this thread. That transmitter failure is a strange one, but I'm glad it ended well. Using small LiPos and swapping them out after one or two flights is a very sound strategy for folks flying aggressive 3D. Mere mortals are probably well served with a larger pack suitable for as many flights as they'll make in the day with the air frame, e.g. most especially those who take two or even three models to the field. Anyway, LiPos as compared to NiCds have such an advantage in energy density it's ridiculous! And we'll see the day when the advantage doubles from here!
Jan 15, 2020, 09:07 PM
Canucklehead
My 60" is getting a new lease on life.
Sent from my iPhone using Tapatalk
Latest blog entry: Little bout me
Jan 16, 2020, 02:22 AM
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
Nicely done!
It's also reassuring to see the LG undercarriage looks pretty much unscathed.
Jan 16, 2020, 03:29 AM
I fly, therefore, I crash!!!
SteveT.'s Avatar
Agreed, nicely done..
SteveT.
Latest blog entry: My shop....
Jan 16, 2020, 08:06 AM
Big Bushy with a STING (errrr)
Chris SW's Avatar
Nice work Bandit. They really are too nice a plane not to fix them.
Discussion Extreme Flight - 3DHS 79" Slick 580 blucor basher 3D Flying 2034 Jan 20, 2020 02:59 PM
Article Extreme Flight 52" Slick 580 EXP EXTREME FLIGHT 3D Flying 4224 Jan 09, 2020 10:04 AM
Article Extreme Flight 74" Slick 580 EXP blucor basher 3D Flying 5238 Jan 08, 2020 07:16 AM
Discussion 3DHS 60" Slick 580! EXTREME FLIGHT 3D Flying 1709 Sep 25, 2018 12:34 PM
Discussion 3DHS 60" Slick 580 V2 Red/White jobinseattle 3D Flying 22 Nov 23, 2017 12:27 PM
