HobbyKing Refines the H-King Bixler 2 - RC Groups
The HobbyKing Bixler has long been a favorite plane for its great flying characteristics for beginners and FPV pilots alike. Now they have a new version with some great improvements.
The Bixler 2 Gets a New Look and Improved Features
The HobbyKing Bixler has long been a favorite plane for its great flying characteristics for beginners and FPV pilots alike. We have to give a nod to the Multiplex EasyStar that decades ago gave birth to this style of foamie. This new version of the Bixler 2 brings some great improvements to the platform and it's available in ARF or PNP form. The plane is made from EPO foam and everything is already installed at the factory. The wings plug in so you can take them off easily if needed for travel. With the new larger canopy area, you can fit in a larger range of batteries or more easily fit your FPV gear. It has built in pre-hinged flaps so you can add your own servos to make them functional and get even slower flight speeds and shorter landings.
The tail section has been redesigned and allows the use of a lower kv brushless motor with a larger prop that provides more thrust and much longer flight times. That's a huge bonus when learning to fly or when you are having too much fun FPVing. There several other changes like a larger wing, better cooling and a landing skid that make this the best Bixler yet. When I saw the announcement I was sure this was going to be around $150 or more, but man the PNP version is only $88.19, incredible!
Check out the H-King Bixler 2 at HobbyKing
Features:
  • Easy, Fast and Simple Assembly
  • New Larger Canopy area to accommodate FPV equipment and/or larger flight battery
  • Pre-Installed Servo's & Brushless Motor
  • Larger Wing Span for greater glide & Payload Carrying Capability
  • Bigger air inlet to keep the motor cool.
  • Plastic Landing Skid
  • New, lower KV Brushless Motor/larger Prop Combo for Greater Efficiency
  • Pre-Installed Optional Flaps Mounted on Plastic Hinges (require Servos for operation - not included)
  • Plug In Wings for Easy Transportation
  • Pre-Installed Round Pin Hinges on Rudder & Elevator
Specs:
  • Material: EPO Foam
  • Wingspan: 1500mm
  • Length: 963mm
  • Flying Weight: 760g
  • ESC: 20A
  • Motor: 2620-1300KV Brushless Outrunner
  • Servo: 4 x 9g
  • Prop: 7x5
Oct 05, 2017, 04:51 AM
Looks like the older Bixler 2 with new decals and a solid foam canopy. Any other changes? Thanks.
Actually, the Bixler 2 was always my favourite Bixler (I've owned/flown V1.0, 1.1, 2, and 3's) for FPV so I'm glad to see it re-introduced. I have just ordered a nice new one. Cheers.
Oct 05, 2017, 02:53 PM
Too noisy. My mine gripe about most FPV planes.
Oct 05, 2017, 04:26 PM
Sorry, but I do not understand what you mean.
Oct 05, 2017, 05:51 PM
I have the Bixler 2 KIT and the new refined Bixler 2 seems to be exactly the same airframe, except the refined Bixler has a opaque canopy and different graphics.
What have been refined or improved?
Oct 05, 2017, 06:53 PM
I thought the idea was that the motor is mounted higher so you can have a bigger prop.
Oct 05, 2017, 06:58 PM
Both the Bix2 and Bix3 are higher mounted motors to allow for bigger props. These come with a 7 inch prop while the older Bix1 and Bix1.1 both come with a 6 inch prop.
Edit; actually I think I recall that the Bix1 also came with a 5-inch prop. I seem to remember that this was a very noisy at anything above 50% throttle. About the same as an HK Funfighter imho.
Oct 05, 2017, 07:48 PM
Category Manager - Planes
HobbyKing_Ian's Avatar
The main change is the in the power system. Better motor and ESC combo based on customer feedback
Ian
Oct 05, 2017, 11:22 PM
Thanks Ian
Oct 06, 2017, 12:59 AM
DFS#000178
Rampage's Avatar
The only way to get a quieter plane is to go with a twin.
Pushers are always and will always be loud. A twin or a pod puller might be better for you, but a pod pusher or any pusher is going to be really loud.
Oct 11, 2017, 01:13 AM
Ya, my Multiplex brushless TwinStar 2 (w/ 2x 8x5 props btw) is a bit quieter and has that beautiful twin-sound! It's also nice to be able to program the motors for differential throttle (= lots of Yaw control!).
Maybe some time in the future HK will come out with a twin-motor Bixler. Here's my TS2 on floats. It's a great floatplane and with packing tape on the bottom of the floats it taxi's and takes off from my flying club's grass strip no problem. Also, with diff throttle (I can turn this on/off with a mix switch) you do not need a water-rudder when taxiing on the water. Sorry to get a bit off topic. I just got my nice new Bix2 today so I will post how I make out with it this weekend;
Oct 11, 2017, 02:51 AM
great plane.it comes almost ready to fly.works perfectly,machine with high precision.worked great on my bix2. very good product. easy to fly and really nice video i really like it.
Oct 13, 2017, 05:36 PM
I maidened my nice new Bix2 PNP a few days ago.It fFlew fine, pretty well same as my old Bix2 (no big surprise!). With a 3s2200 pack it was no hotliner with unlimited vertical performance, but it was still quite adequate. It took ~10-15sec to climb to ~100m.
The only 2 problems I had with my new PNP were;
- the stock 7x5 prop is poor quality imho and it was very hard to balance properly. I will replace this with a much better quality APC 7x5e prop.
- the new decals are very nice but they do not provide any structural strength like regular mylar decals. After a couple of loops, the outer end of the wing spar'cover (on both wings) broke through the black bottom decals. They are thin/rubbery and are very easy to peel off. No big deal, I just peeled off the rest of these and used some white coloured reinforced duct tape to secure the spar/cover. Then I added added 3x black stripes with black coloured reinforced duct tape.
Another complaint is that both aileron servo arm holes installed on my PNP were too large so there was lots of slop. The easy fix for me was to just go in one hole on each servo arm and carefully enlargen it just enough to insert the z-link.
Also, it would have been nice to have had the rudder control tube/wire aligned so it could go directly to the rudder horn. As it is, you need to do a couple of bends in order to avoid rubbing against the stab and getting it to properly line up with the rudder control horn.
The air intake hole on the front of the Fuz collects a lot of grass/dirt and directs this into your battery area. I found it best to cover this hole and add a couple of front/side cheek-holes.
Of course, you should also add little keeper bands (I just use a short piece of silicon tubing) to help secure all control clevis links.
The new silver coloured canopy is not solid foam btw. Underneath the silver plastic cover, it's the same as the original Bix2. I like the look of the new one though, including the new decal colours.
Overall, I am happy with my new Bix2 pnp, esp given it's low price. Cheers.
Dec 17, 2017, 09:44 PM
Hi all. I'm new to forums, and new to RC fixed wing. I started off flying some toy grade quadcopters and moved on to a couple toy grade 3 channel planes, then I wanted to get a hobby grade fixed wing, and I chose the Bixler 2. I got that last month -- the new version Bixler 2 PNP, but I had to wait until I got my TX and RX which I got today. I had already glued on the horizontal and vertical stabs, but it was rotated off by a lot so I cracked the tail part of the fuse and realigned it, so that fixed that no problem. But now I took my new transmitter and calibrated the throttle, then I noticed the pre-installed servos aren't centered. So I checked my TX trims and subtrims and they are centered, so I guess whoever assembled it didn't center the servos. It's so far off that trimming or adjusting the clevices won't work. So now I'm waiting for HK product specialist to email me, I did the live chat on the web site but he said he would forward my concerns. Ok so I could rip out the pushrod guides and servos and access the control arm that way.. or maybe I could poke a hole from the bottom of the fuse to access the screws and reposition the control arms that way.. but um is this common or normal or what? Sorry for the rant and venting, but I'm just so bummed out about it. It would be easy if I could just access those servo screws.
** I went for poking a hole through.. it wasn't so bad as I felt it would be. All fixed now.
New Product H-King Hall Cherokee from Hobbyking AGT6 Electric Plane Talk 163 Feb 27, 2017 02:45 AM
Discussion HobbyKing Discontinues the 'H-King Color 250' Quad After 2 Days of Being Release? sean.belardo Multirotor Drone Talk 6 Jun 20, 2015 11:26 AM
Discussion H.King BIXLER 2 RC Plane. Lost/Found thumper007k Australia 0 Aug 31, 2014 08:00 AM
