Jeti Central Box 100 Power Distribution Unit (Mini Dual Redundant System) - RC Groups
With Jeti Duplex 2.4GHz DC/DS transmitters, the full potential of the Central Box can be used, such as an easy way to wirelessly configure the Servo Outputs, EX Telemetry, Fail-Safe Setting or Fast Servo Response.
The Central Box
From Jeti
The Central Box 100 is a switchboard designed for the complete management of servos in an RC model with an emphasis on safety. The Central Box has a unique design that provides overload protection at each servo output. The Central Box can manage up to 8 servos and fully supports the Jeti EX telemetry system. Up to 2 receivers with serial (PPM, EX Bus) output can be connected at the same time to the Central Box for complete RF signal redundancy.
With Jeti Duplex 2.4GHz DC/DS transmitters, the full potential of the Central Box can be used. Such as an easy way to wirelessly configure the Servo Outputs, EX Telemetry, Fail-Safe Setting or Fast Servo Response.
A Closer Look: Jeti Central Box 100 Mini Redundant System w/Dual Rx, Batteries & Wireless Switch (4 min 55 sec)
Features:
  • Control Management with Configurable Servo Output
  • Power Distribution with Overload Protection
  • Firmware Updatable via Jeti USB Adapter
  • Jeti Duplex EX Bus or PPM Compatible
  • Wirelessly Programmable Using DC/DS Tx Device Explorer
  • Independent Receiver Signal Inputs (Rx 1, Rx 2)
  • Up to 8x Servo Outputs with Overload Protection
  • Up to 3x Telemetry Sensors Inputs
  • Output Current: 10A Continues/90A Peak
Fail-Safe Setting
  • Switches ON/OFF of the Fail-Safe function. If the Fail-Safe function is deactivated, there is no signal generated in any Central Box outputs at the signal loss. If you activate the Fail Safe function, you can also select how the Central Box responds at signal loss for each of the individual outputs.
  • Jeti Central Box 100 Power Distribution Unit
Servo Mapping
  • Servo No. - Assigning outputs of the transmitter to the Central Box outputs.
  • Group - Assigning specific output to the group of output impulses that will be generated from the receiver in the same time.
Duplex Telemetry
  • Temperature - Temperature of the Central Box
  • Shorted Outputs No. - Number of Overloaded Outputs
  • Voltage - Voltage of Individual Outputs of the Central Box
  • Current - Current Drawn from the Battery
  • Capacity - Capacity Taken from the Batteries
Learn More
Head over to the Esprit site for more info.
New Product Redundant power distribution board for 3S to 10S (with reverse voltage protection) Auvidea Multirotor Drone Electronics 7 Aug 31, 2017 02:56 PM
Discussion Video: Jeti 2.4GHz and 900MHz Dual Band Redundancy Link w/R3 & DC-24 Esprit Model Radios 0 Mar 24, 2017 12:49 PM
Discussion T1-S flight controller with dual redundant system and high precise external IMU TopXgun Multirotor Drone Electronics 0 May 20, 2016 04:38 AM
Discussion Jeti Electronic Dual Redundant R/C Switch with Power Backup & Magnet Esprit Model Radios 0 Apr 04, 2015 07:14 PM
Article Jeti Central Box 200 Power Distribution Unit w/Magnetic Switch Jason Cole Radios 1 Sep 04, 2013 09:40 AM
