Oct 02, 2017, 08:19 AM
Help!
setting up gyro on 450
Need help in setting up gyro on my 450 helicopter. It has a ZD720 gyro. When I spool up, the heli starts spinning. Please help
Oct 02, 2017, 10:12 AM
rc user
pdooley's Avatar
most likely your gyro direction.
but you need to verify your mechanical setup is correct too.
i suggest anyone with trouble to watch these videos:
Tail Rotor Basics Part 1 (4 min 1 sec)
Tail Rotor Basics Part 2 - Gyro Gain (7 min 32 sec)
Oct 03, 2017, 10:35 AM
hi might help to know what tx is being used
Oct 03, 2017, 12:01 PM
I am using ZD flyT-6A transmitter and ZD720 gyro.
Oct 03, 2017, 12:07 PM
rc user
pdooley's Avatar
I don't think Tx matters that much. simple PC program model or more advanced, doesn't make much difference.
he's using a simple flybar tail gyro, but still no word weather or not he tried changing gyro direction..
or watched the videos and made sure setup is correct..
Oct 03, 2017, 12:19 PM
I have seen the video, Will test the helicopter tomorrow. Direction of the servo is correct.
Oct 03, 2017, 12:31 PM
Heligamist
BrokeDad's Avatar
I usually put a little pitch in the tail blades at center stick to offset the rotational force
Oct 03, 2017, 01:14 PM
rc user
pdooley's Avatar
not just servo direction when you push the transmitter stick but also check compensation direction.
Oct 03, 2017, 01:15 PM
rc user
pdooley's Avatar
this should be automatic if flying in HH mode.
some people mess with setting up rate mode first, that's fine if you plan to fly rate, but i just center my servo arm and pitch slider and fly HH mode.
Oct 03, 2017, 01:23 PM
I have done some setting on the tail servo, will test tomorrow.
Oct 03, 2017, 02:03 PM
Heligamist
BrokeDad's Avatar
Old habits are hard to break. At least I don't ever fly in "no gyro" mode like you.
Oct 03, 2017, 03:09 PM
rc user
pdooley's Avatar
it will def keep you on your toes
Oct 04, 2017, 10:13 AM
hi,makes difference if you have to tell somone how to set gain to plus 70 ,if using that for starting point
Oct 04, 2017, 10:24 AM
rc user
pdooley's Avatar
his heli is spinning around, it's not gain related.
Oct 05, 2017, 01:18 PM
okay so I tested the heli and there is some difference, now the heli is spining very slowly, need to adjust the postion of the tail servo
Discussion Newbie need help setting up a QQ flite controler on a 450 qud leftys81 Beginner Multirotor Drones 0 Jul 18, 2016 02:19 PM
Discussion Hobby Eagle A3L Gyro Set Up MIGPILOT44 Flight Accessories 0 Apr 27, 2016 06:03 PM
Question 3gx gyro mixing set up Tech9 3D Electric Heli Flying 6 Nov 23, 2015 11:36 AM
Help! Setting up CSM SL420 Gyro on Trex 450 spityman Mini Helis 0 Mar 29, 2009 09:58 PM
Help setting up Ikarus Micro Gyro on Hummingbird WeatherB Micro Helis 2 Dec 27, 2004 03:03 PM
