Electronic Pre-rotation System (EPS) - RC Groups
Oct 02, 2017, 03:34 AM
TrueBuld's Avatar
Who supplies EPS systems and how do they work?
If they work by sensing the lower end of the throttle movement and disengage at takeoff throttle setting, do they automatically start again to assist landing?
Oct 02, 2017, 03:58 AM
britinoz's Avatar
I'm pretty sure that most units would be scratch built using heli gears and shafts...that are manually started prior to flight...and turned off just prior to lift off....but why would you ever require to start again for landing ???
If the rotor stops in flight ....your in big trouble
Happy landings
Chris...
Oct 02, 2017, 06:12 AM
TrueBuld's Avatar
EPS (Electronic Pre-rotation System)
Happy landings
Chris...
The GyrOne assembly manual has a picture of an electronic gizmo that is called an EPS (Electronic Pre-rotation System).
The photo of parts seems to show a circuit board, disc and a magnetic/photo-optic sensor.
So I can only assume it is an addition to the manually (via TX switch) activated electric motor pre-rotation.
Oct 02, 2017, 07:02 PM
britinoz's Avatar
If you question was in relation to the Gyro One.....then possibly you could have mentioned it.
I presumed it was a general question.
Chris...
Oct 02, 2017, 11:00 PM
Jockadopolus's Avatar
I believe the EPS system was a visual indication with lights to show the rotor was up to speed
I will try to find out more info
Joe
Oct 03, 2017, 03:03 AM
TrueBuld's Avatar
Chris...
It was a general question, and I was mindful that stating one specific model would narrow the discussion.
Discussion Pre-rotator wiring diagram mnowell129 Auto Gyros 0 Apr 19, 2007 03:50 PM
Discussion My pre-rotator works! mnowell129 Auto Gyros 40 Oct 17, 2006 03:13 PM
Question BEGi pre-rotator spool up InspectorGadget Auto Gyros 15 Jun 20, 2006 01:35 PM
Discussion Pre-Rotator update mnowell129 Auto Gyros 2 Mar 15, 2006 03:24 PM
are gw/eps motors normal or reverse rotation motors? daltrey Electric Plane Talk 2 Dec 11, 2004 12:56 PM
