Peter Goldsmith Designs Foxbat Sailplane Kit
Building season is just around the corner and it's time to start looking for your winter projects. Peter Goldsmith has an awesome retro sailplane kit that looks great and should fly even better.
Pick Up this Great Kit for Building Season
Building season is just around the corner and it's time to looking for your winter projects. Peter Goldsmith has an awesome retro sailplane kit that looks great and should fly even better. The Foxbat can be built as a pure glider or you can set it up for ALES with an electric power system. Peter has just started to get kits together so if you want one, you'll need to send him a message to get on the list.
The kit costs $280 plus about $10 in shipping. He said he tried to keep the costs down as much as possible to encourage people to pick up building again. The skills you learn while building will help you greatly in the RC hobby and there is nothing like the feeling of flying a model that you built yourself. You should give it a try!
Editor's Note
We did a little research and the word on the street is that you can contact Kennedy Composites to order this plane.
Oct 01, 2017, 03:23 PM
Randy Reynolds's Avatar
Specifications?
Oct 01, 2017, 05:28 PM
AKA - The "Flywheel"
StevenatorLTFO's Avatar
3.6 meters.
Oct 01, 2017, 07:54 PM
Yes....and?....
Oct 01, 2017, 08:47 PM
Thats all I know... LOL
Oct 01, 2017, 08:53 PM
Well, it's a very good specification and much appreciated :0)
Oct 01, 2017, 09:13 PM
R.M. Gellart's Avatar
Randy, Pete designed this ship in the late '70's when still in Australia. It has been accepted for Nostaglia legality, and like anything Pete, is nicely engineered. Pete is laser cutting the kit himself, Barry Kennedy is distributing the kit. I have one on the way myself.
Just good common sense design and construction methods.
Marc
Oct 01, 2017, 10:19 PM
Good info....any idea of the airfoil? If it's Nostalgia era I assume it's a flat bottom.
Oct 01, 2017, 11:22 PM
prodjx's Avatar
It looked and flew very well at the last SW Glider Contest I attended.
Oct 02, 2017, 08:09 AM
Randy, it is SD3021'ish I am guessing...
Marc
Oct 02, 2017, 12:21 PM
Larry Jolly's Avatar
Mark
I haven't checked one out but question the use of a 3021???? Since Nostalgia cut off is pre Jan 1980 and The 3021 is several years later. L
Oct 02, 2017, 12:27 PM
Sagitta Fanboy
Originally Posted by Larry Jolly
Mark
I'd suspect Marc means it's similar to a 3021, ie a modified E205 type foil.
Oct 02, 2017, 12:35 PM
E 193
Oct 02, 2017, 12:54 PM
The King Moonracer of balsa.
Windependence's Avatar
Originally Posted by Randy Reynolds
Specifications?
Hi Randy, maybe this will help.
All up weight is around 56 0z
Airfoil was originally an Eppler 193, not sure what the kit has
3.6 meter span
Built up wood wing and fuselage
RES design
Peter posted some of his build pictures and a little history on the design in this thread: https://www.rcgroups.com/forums/show...o-more-designs
Wayne
Larry, I did say 3021'ish, not 3021. Last time I checked, adding the suffix -ish means it is sort of like it, but not it.
English class is done...
Marc
News Peter Goldsmith - 3rd Place ALES 2013 awagar Sailplane Talk 3 Jul 26, 2013 10:16 PM
Discussion Peter Goldsmith - Team Capt. of JR Jim T. Graham AMA Expo 0 Jan 16, 2008 02:05 PM
