Comoz Twin - Page 4 - RC Groups
Oct 10, 2017, 10:50 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Hi elewon, I have used this motor quite a few times with 8 x 4.5 prop without any problems .. although I am no expert when it comes to electrics .. maybe my good friend Duke could give us his expert advice on this
Lockey
Oct 11, 2017, 12:25 AM
Careful,.. confident,.. CRASH!
Dukejet's Avatar
Hahaha...ex-pert.....
Well I would love to test this little motor with a tester to be sure. But I'm very confidant it will be fine. I have the 3536/5 1450kv, 3548, 2826, in the series of motors. I have found them to be under-rated with amps. My EFX Racer is running the first one mentioned and its happy running 50amp constant and 65amp peak. She's running an 8x8 on 3s and 8x4 on 4s.
100MPH+
Would love to see some figures on a wot bench test..... Lockey...
Oct 11, 2017, 02:26 AM
Lockey's Avatar
I managed to get out and maiden the Comez .. with my one and a half eyes .. maybe I would have been better stay at home .. judge for yourself
You will notice I cut the sound at about 40 seconds in .. I will leave it to your imagination as to why !!: censored: it was VERY uppy at high throttle .. I should have put some downthrust on the motors and I think it might have been a little tail heavy
Lockey
Comoz Crash (1 min 8 sec)
Oct 11, 2017, 02:55 AM
Lockey's Avatar
Well .. A real quickie repair, need lots more work to get it looking anything like .. BUT .. repaired enough to have another go
Put a packer under the the top of the engine mount to give the motors a bit of down-thrust, moved the battery a little further forward and .. here is the result
Retracts will need some beefing up (maybe more ply ??) not sure .??
Lockey
Edited Comoz Maiden (3 min 17 sec)
Oct 11, 2017, 03:50 AM
Lockey's Avatar
Hey Duke .. how about this one .. http://newatlas.com/spike-aerospace-...7416c-90255646
Lockey
Oct 11, 2017, 07:17 AM
scorchythebear's Avatar
Shame about the maiden! I think a bit of colourful language is perfectly allowable in such circumstances.
Looks better in the second video, it has a beautiful silhouette against those clouds. Very elegant!
Oct 11, 2017, 09:15 AM
Ouch, glad she was repairable and that you got her flying better. They always seem to fly better after a bit of crinkling.
Oct 11, 2017, 04:30 PM
Dukejet's Avatar
Oh man.... what a shame. Good on you for persisting mate.
Twin motors are not easy to setup. The ding bat realy had me scratching my head... I see you set them up level with each other.... but they must be lined up on 3 axis, using you main wings flat bottom as you 'datum"......
For me mate... you either sware or cry. I choose......... both...... lol...
Oct 11, 2017, 04:39 PM
Dukejet's Avatar
Lockey
Man thats scarier that the Zirconia ..... ie Lawndart!!!! As David would say.....
Oct 11, 2017, 10:50 PM
Lockey's Avatar
Hey Duke .. you never answered my burning question ... can't decide if I should go std tail or V tail on the ME262 HG2 .. which do you think ? ..
Man, you are gonna want to build this one, its even sexier than the ME262 HG1 and you already built the ME 262 HG3
Lockey
Oct 12, 2017, 01:45 AM
Dukejet's Avatar
Now your feeding my fetish!! .... Of course Vtail!! Looks cooler.....
Oct 14, 2017, 09:10 AM
Lockey's Avatar
New model is now finished .. Sea Scout .. this is a SOG and water plane with thrust vector rudder .. 700 wing span ..Turnigy D2826-6 2200kv Motor with 6 x 4 prop .. 40 A ESC .. 3 x 9g servos. and uses about one and three quarter sheets of 6mm Depron and would estimate weight at about 700-750 grams including 1500 - 1800 / 3s battery
Still working on the ME262
Lockey
Oct 14, 2017, 01:16 PM
Out Standing In The Field
RexGalore's Avatar
^Lockey, the Sea Scout looks terrific!
The only problem is that I want a full-scale one!
Oct 14, 2017, 10:12 PM
Lockey's Avatar
well Rex .. just scale it up by a few 100%
I guess when it really comes down to it ... its really just a variation on my VIXEN which is really just a variation of the famous POLARIS
Lockey
Vixen Maiden (3 min 17 sec)
Oct 16, 2017, 02:55 AM
Lockey's Avatar
I bought 23 sheets of 3mm Depron from a guy the other day (cheap) and wondered what I could make with 3 mm Depron .. any ideas guys ??
Lockey
EDIT ... I found this a long time ago .. SAF-14 .. not much info on the building of it but I did once see a couple of videos and it seemed to fly real nice (tried to find the videos but it seems these have gone too) .. I see its on Park Jets (http://www.parkjets.com) but cant get any info .. seems its not there any more .. is anyone a member ?? and could check it out for me
I could reverse engineer it I guess I do have a few pics and REAL rough drawings .. the whole thing is designed to be made from 3mm Depron
This was designed by a guy named Eduardo Flores .. just did a search on You-Tube and you wouldn't believe how many guys with the same name there are .. doh!!
Discussion DLE-40 Twin vs VVRC/RCGF-40 Twin tommyt Giant Scale Airplanes 1 Aug 09, 2017 10:32 PM
Discussion Twin stick radio for twin screw tug? AggressorBLUE Dock Talk 22 Jun 27, 2017 10:58 AM
Build Log FT TWIN EXPLORER, a twin motor FT Explorer peter97silva Foamies (Scratchbuilt) 5 Feb 20, 2017 02:40 PM
Discussion Twin Motor - Twin ESC setup issue Bowman44 Scale Boats 29 Sep 08, 2016 04:18 PM
Discussion Futaba 10J programming for twin motor / twin rudder Spellbound714 Dock Talk 2 Jul 04, 2016 12:20 AM
