Feb 09, 2018, 01:29 PM
marksp's Avatar
Originally Posted by marksp
Iíve got the VVRC Gen2 engine fitted. Not wanting the hack cowl, Iím using the VVRC 2:1 header with the MKS 75mm canister. Engine fits completely inside of cowl.
Iím on the road through end of week, so no pics, but iíll get some pics posted this weekend
Cowl on, exhaust exit
Cowl on, prop off
Cowl off
Header + canister
Latest blog entry: Hangar 9 Timber 110
Feb 09, 2018, 02:14 PM
We shall serve the Lord
kingsflyer's Avatar
That's one SLICK installation! Nicely done!
McD
Latest blog entry: LEDs on my T-28
Feb 18, 2018, 09:20 PM
Very nice. How does it balance out?
Feb 22, 2018, 03:15 PM
tailskid2's Avatar
Marksp, you did a great job mounting that engine. VERY well done! Where is your CG located?
Feb 22, 2018, 09:28 PM
marksp's Avatar
Travelling much more than not so unable to get my CG/AUW notes. Plan to get a few days home soon, so hope to share details.
The big challenge I'm struggling with is access to wing bolts. Combination of large hands and pull-pull wires, results in so much frustration that plane sits on shelf. :-(
Cheers
Feb 22, 2018, 09:40 PM
kingsflyer's Avatar
Wing bolt access is not the best on the RV-4. I usually have to twist the rudder servo hard over so that my fingers can get down to the screw area. It's not perfect, but it's the best solution I've found so far.
McD
Feb 22, 2018, 09:53 PM
vollrathd's Avatar
Battery Compartment?
What is the length, width and height of the location where a electric motor battery will go? I'm thinking A123's here.
tailskid2's Avatar
Those bolts sure are long And mine are PINK!
Feb 22, 2018, 10:11 PM
tailskid2's Avatar
I would NOT worry about space for batteries! That's a 30cc smoke tank on the side and two flight batteries on the far left....TONS of space for your batteries. The battery tray measures ~10" by 5+" and is removable.
Feb 23, 2018, 12:00 AM
vollrathd's Avatar
Can you provide vertical clearance under the semicircle at the middle of the battery tray?
If my A123's fit, I may go this route for my Hacker A60-16M and its 19X12 prop.
Feb 23, 2018, 12:18 AM
tailskid2's Avatar
4.5" from the floor. The battery tray lies on top of that a bit but I don't know how much.
Feb 23, 2018, 12:55 AM
vollrathd's Avatar
Thanks, it's appreciated
So, per the attached photo, the vertical clearance at the arrow location is well over 3 inches?
(Standing on end, my A123 packs are 2.9 inches high.)
Feb 23, 2018, 01:04 AM
vollrathd's Avatar
McD
H'mmm
I have a Extreme Flight Turbo Bushmaster that also has its wing bolts located a fraction of an inch from the wing tube. Pain in the to tighten down. Solution was to take a 3/8 inch diameter wood dowel around a foot long, cut a slot in one end to insert over the wing bolt, and spin it on or off.
That works very well.
Wonder if that would work on the RV-4, but it would require a small diameter access hole on the opposite side of the fuse to insert the dowel. Or perhaps epoxy on a phillips screw head into a wood block, and epoxy that block to the wing bolt. Then build up a small diameter phillips screw driver with an extra long shank to screw it up, again needing holes on each side of the fuse.
Feb 23, 2018, 01:11 AM
vollrathd's Avatar
Dang
I see that delivery is for late March???
Feb 23, 2018, 01:58 AM
tailskid2's Avatar
At that point it is 3.25"
New Product Hangar 9 Van's RV-4 30cc ARF 85" Bajora Giant Electric Planes 319 Aug 14, 2019 01:31 PM
Article Hangar 9 Van's RV-4 30cc ARF 85" Jason Cole Joe Nall 2017 5 Mar 22, 2019 08:59 PM
Discussion Hobbyking Van's RV-4, 1600mm Diesel6401 Sport Planes 27 Jul 06, 2015 09:28 AM
Build Log Van's RV-4 HobbyKing ARF Riffo Fuel Plane Talk 13 Apr 28, 2015 10:43 PM
Build Log 1/4 scale Vans RV-9 from 4 sheets depron RJPIoW Foamies (Scratchbuilt) 29 Jun 30, 2014 01:46 PM
