I think it will be 4x4 if the 13T pinion allows me to space the motor away from the axle transferring power to the front.
If not i will have to find a much bigger pinion like 17T or 19T. Also i hope to make this all wheel steering aswell |
I found this 21T pinion:
http://www.ebay.com/itm/RevCo-Hard-O...EAAOSwWKtUsqIJ I guess i will buy it, this will surely help me space the motor away from the central drive shaft |
Anybody else found suitable pinions ?
Should i buy the 21T pinion ?
Trying on bigger wheels, 103mm diameter :
Hello,
I need some suggestions for a high torque motor that will be able to turn those big wheels. I guess it will be a brushed one because otherwise i will have horrible cogging like i did with the Kyosho Smax I already have some small 2440 brushless motors @ 4000KVand 4600KV but i think i need lower KVs |
Does a 540 fit ?
When i used a 540 motor on the Kyosho Smax build the motor was blocking the central plastic shaft transmitting power to the front wheels. Plus the 540 motors have a different shaft diameter and the pinion will not fit. I had that issue with Kyosho Smax aswell and ended up using a helicopter pinion and an L mount to install the motor I just need a better 390 brushed motor or a very low KV brushless. Can i use the original Feiyue motor ? is that supposed to be better than the one in Remo ? I need torque since i am turning the Remo into something like a Monster Truck. I also want a motor that will do 3s |
is this drill motor an option ? :
https://www.ebay.com/itm/DC-6V-24V-1...4AAOSwiYFXFfg4 Goes up to 24 volts and i only wanna 12v on it |
The price is cheap and the dimensions seem correct 390 can with 2.3mm shaft.
So i may risk it |
Look on Hobbyking for a 0.7m pinion https://hobbyking.com/en_us/catalogs...t/?cat=&q=0.7m.
Get a 5mm to 3.175mm reducer like this https://www.amazon.com/Robinson-Raci.../dp/B0015BJNH4 Then get a 2845 brushless motor of your choice they are roughly the same size as a 390 brushed motor. |
Thread Tools | |
Similar Threads | |||||
Build Log | Kyosho Raider + Remo 1/16 Truck = Frankenstein diy car | biomecanoid | Off-road Cars | 510 | Apr 28, 2019 05:02 PM |
New Product | REMO 1/16 RC Short Course Truck Car Kit With Car Shell -FREE TEST | BG Tobey | Car Talk | 140 | Feb 26, 2018 07:56 PM |
Mini-Review | Remo 1/16 DIY RC Desert Buggy Truck Kit RC Car | emu26 | Micro Cars | 49 | Sep 01, 2017 06:49 AM |
New Product | REMO RC Car 1/16 RC Car Off-road Buggy Kits With Car Shell --Seeking reviewer | BG Tobey | Off-road Cars | 24 | Jan 14, 2017 10:24 PM |
New Product | Remo 1/16 DIY RC Desert Buggy Truck Kit RC Car without Electric Parts -- FREE TEST | BG Tobey | Off-road Cars | 11 | Dec 26, 2016 06:54 PM |
