Detrum Sentan Multi-Rotor Flight Controller System
Detrum Sentan is a flight control system for nearly all multi-rotor types which contains flight controller, GPS+Compass module, LED module and PMU module.
Detrum Sentan
Detrum Sentan
During the flight, Sentan can measure flying altitude, attitude and the battery status in order to make real time adjustment for drone. It makes the operation more intelligent and brings more joy to pilots.
Features:
  • High performance CPU, barometer and 6-axis gyroscope are all integrated in small one which makes this module lighter and smaller.
  • Adopted by Detrum, this advanced control algorithm makes the control accurate and the flight state not only steady but also flexible. It can bring the excellent flight experience for pilots.
  • Equipped with high precision GPS+Compass module, Sentan flight control system will have position and altitude locked accurately, can achieve the Retrun-to-Home and Intelligent Orientation Control functions perfectly. The accuracy is 2.5m in horizon and 0.8m in vertical direction.
  • The PMU module can monitor the battery voltage and current in real-time to ensure the aircraft can achieve the Low Battery RTH.
  • Support multiple flight modes such as attitude mode, altitude hold mode, GPS attitude mode, circle mode, course lock IOC mode, home lock IOC mode and RTH mode. Users can switch freely between different modes.
By using Intelligent Orientation Control (IOC), allow the pilot to control the movement of the copter from the pilotís point of view regardless of which way the copter is facing.In course lock flying, the forward direction is the same as a recorded nose direction. In home lock flying, the forward direction is the same as the direction from home point to multi-rotor.
There are three types of RTH procedures: smart RTH, low battery and radio failsafe RTH. It makes your flight safer. Detrum Sentan flight controller supports 4 auxiliary channels which can connect with gimbal, landing gear and etc. This can make the flight much more interesting and satisfy the demands of different users.
The Sentan flight controller is compatible with PPM (eg. Detrum RXC6 and RXC8), S.BUS and DSM receivers, can support most of the commonly used receivers on the market today.
Detrum Sentan flight control system is applicable for Quad-rotor +4, 330 Quad-rotor X4, 450 Quad-rotor X4, Hexa-rotor +6, Hexa-rotor X6, Hexa-rotor Y6, Octo-rotor +8, Octo-rotor X8, Octo-rotor X8.
User can configure the Sentan flight control system in the PC ground station software to get the better performance.
What does the system include?
  • Master Controller
  • GPS+Compass
  • PMU Module
  • LED Module
The LED Module will indicate the state of the flight controller.
Multiple Flight Modes
  • Attitude Mode
  • Altitude Hold Mode
  • GPS Attitude Mode
  • Circle Mode
  • Course Lock IOC Mode
  • Home Lock IOC Mode
  • Several RTH Modes
Support multiple flight modes such as attitude mode, altitude hold mode, GPS attitude mode, circle mode, course lock IOC mode, home lock IOC mode and RTH mode. Users can switch freely between different modes. Obviously, the Sentan flight control system makes the flight more intelligent and brings more fun.
  • (Attitude Mode, Altitude Hold Mode, GPS Attitude Mode, Circle Mode)
  • (Course Lock IOC Mode, Home Lock IOC Mode)
  • (Smart RTH, this function can make your aircraft automatically return to the last recorded Home Point by one switch.)
Wide Range of Application
  • Support four auxiliary channel
  • Compatible with kinds of receiver
  • Support many types of multirotor
  • Easy to adjust parameter
It supports 4 auxiliary channels which can connect with gimbal, landing gear and etc.
Itís compatible with PPM (e.g. Detrum RXC6 and RXC8), S.BUS and DSM receivers, can support most of the commonly used receivers on the market today.
Specification:
  • Application: X-type Quadcopter, X-type Hexacopter, Y-type Hexacopter, X-type Octocopter, coaxial X-type Octocopter
  • Auxiliary Output: 4
  • Support ESC Output: 400Hz
  • Transmitter: PPM, SBUS, DSM
  • Input Voltage Range: Master Controller: 4~6V
  • GPS+Compass: 4~6V
  • LED: 4~6V
  • PMU: 7~28V
  • Power Consumption: Master Controller: 1 (200mA@5V)
  • GPS+Compass: 0.3W (60mA@5V)
  • LED: 0.3W (60mA@5V)
  • PMU: 0.08W (5mA@16V)
  • Operating Temperature: From -10℃ to 50℃
  • Assistant Software System Requirement: Window 7/ Window 8/ Window 10
  • Hovering Accuracy (Position Mode): Vertical: 0.8m, Horizontal: 2.5m
  • Max Title Angle: Ī35į
  • Max Horizontal Speed: 20m/s
  • Max Vertical Speed: 4m/s
Dimensions:
  • Master Controller: 67.3mm◊40.1mm◊18.1mm
  • GPS+Compass: 55mm◊14.5mm
  • LED: 27.1mm◊27.0mm◊10.5mm
  • PMU: 47.9mm◊40.1mm◊10.2mm
  • Weight: Master Controller: 36g
  • GPS+Compass: 32g
  • LED: 12g
  • PMU: 60g
Learn More:
Detrum Sentan Multi-Rotor Flight controller system.
Photos
Discussion DJI A2 Multi-Rotor Flight Control System DJI INNOVATIONS Multirotor Drone Talk 237 Apr 29, 2018 06:34 PM
New Product T1 Multi-rotor Flight Controller Link Shane Multirotor Drone Electronics 0 Feb 23, 2017 02:02 AM
Question Is there a reliable Obstacle Avoidance system for DIY multi rotor systems? Cinetography Multirotor Drone Talk 26 Jun 03, 2016 05:23 PM
Discussion HKPilot Mega 2.7 Flight Controller or DJI Naza-M Lite Multi-Rotor Flight Controller dsouza Multirotor Drone Electronics 3 Sep 08, 2015 10:25 AM
Discussion multi-rotor flight controller comparisons - what works/doesn't in different FC's? ryan_m Multirotor Drone Talk 9 Oct 20, 2011 07:26 AM
