This thread is privately moderated by StatiC, who may elect to delete unwanted replies.
Sep 26, 2017, 10:11 PM
forward swept peg installer
StatiC's Avatar
How to thermal useful info
This will be a blog with useful thermal hunting hints that I found throughout the forum so that I can easily read them again after I forget... what was I doing again? Oh yea.
Info on thermals down very low.
https://www.rcgroups.com/forums/show...8&postcount=21
Originally Posted by Don Stackhouse
<snip>
Thermals near the ground tend to be small in diameter, and fairly weak, with very tight cores, although this one was a bit extreme in those regards. In particular, it requires some extremely tight turns, which requires a lightly-loaded plane and some special piloting techniques.
When the diameter of the turn is small, the airflow past the plane is very significantly curved, If the airflow is perfectly aligned with the fuselage at the wing, back at the tail the "relative wind" could be blowing upward (because of the bank angle) and inward towards the center of the turn by as much as 10-15 degrees! This tries to put the nose down, and yaw the plane towards the outside of the turn. If it's a 2-channel rudder-elevator model you need some yaw in that direction anyway, to get enough extra angle of attack at the inside wing tip to compensate for the lower airspeed there, and hold bank angle more or less constant. If the designer was really clever with juggling things like dihedral schedules, tail moment arm, tail design and wing airfoils, the yawing effect of the curvature of the airflow could be just enough to compensate for the effect of airspeed at the inside wing tip. Otherwise, you could need to apply some rudder, although it could be "top" or "bottom" rudder depending on the specifics.
However, you WILL need to apply some "up" elevator, typically a LOT of up elevator in a max-effort turn. How much is "a LOT"? In the example I described above, about twice as much as it takes to stall the plane in level flight!
The catch is that if there is a gust or some other disturbance that momentarily widens out the turn (thereby reducing the curvature of the flow), you have to IMMEDIATELY back off on the "up" elevator or the plane will stall. Once the disturbance has passed, you can ease the plane back into the turn, including the up elevator setting. It's a bit like playing a fish on the end of a line.
<snip>
In higher wind, It might be more important to keep an eye on your streamer. If you caught a thermal and down wind, if your streamer shifts left or right, make note which direction it shifted to as that might indicate the better side to come home.
https://www.rcgroups.com/forums/show...7&postcount=35
Discussion Electric Thermal Technique How-To Video From Paul Naton Paul Naton Electric Sailplanes 1 Jun 11, 2016 10:57 AM
Discussion New Info On Just How Many American Immigrants Are On Welfare kenpoprofessor Life, The Universe, and Politics 0 May 14, 2016 10:05 PM
Discussion How to move dji IOSD mini info down/up? Zot FPV Talk 1 Mar 09, 2016 03:18 PM
Help! Advice on my first quad, used for thermal imaging. evertheylen Beginner Multirotor Drones 0 Oct 05, 2015 02:56 PM
How do I display all Lipo info when using Powerlab 8 v2 with parallel board? Bird09 Batteries and Chargers 2 Jun 25, 2015 09:41 AM
