Tri-flight 0.7 Servo feed back connection on Afroflight 32 Rev 5 ??? - RC Groups
Sep 25, 2017, 03:57 PM
Borneoben's Avatar
Help!
Hi Guys
I have searched for the last two hours where to connect the servo feedback wire to my Afroflight 32 rev 5 board.
It has been flashed with Triflight 0.7 using Betaflight. Servo feedback is set to RSSI in the CLI
set tri_servo_feedback = RSSI
But which pin on the board is the RSSI pin????
I'm going nuts trying to figure this out.
I am assuming its one of the input pins close to the RX connections?
Any advice is greatly appreciated.
Ben
Sep 27, 2017, 08:03 AM
Instead of RSSI, set the feedback input to EXT1 and hook the feedback wire to the PWM6 input.
Sep 27, 2017, 09:01 AM
Borneoben's Avatar
Hi
Thanks for getting back to me.
The PWM input 4 is being used for the RX serial connection?
The PWM output no 6 will be used for the main Servo connection... (not the feedback connection)
Or am i missing something?
Cheers
Sep 27, 2017, 03:01 PM
Going from memory as I haven't used the Naze32 in quite some time:
Servo feedback wire to receiver 6 input (EXT1 adc input) ( Make sure you have the latest 0.7 beta version as the adc input does not work in early versions)
Serial receiver to receiver 4 input
Servo control to PWM out 1
Rear motor to PWM out 3
Right motor to PWM out 4
Left motor to PWM out 5
Use the following resource commands in the cli to set up the PWM outputs correctly.
resource MOTOR 4 NONE
resource MOTOR 5 NONE
resource MOTOR 6 NONE
resource SERVO 1 A08
resource MOTOR 1 B06
resource MOTOR 2 B07
resource MOTOR 3 B08
Discussion Connecting Telemetry X4R-SB and Naze 32 Rev 5. Firepower Multirotor Drone Talk 0 Jul 11, 2016 11:26 AM
Question Naze32 AfroFlight (Rev 5) and MinimOSD kerrycorcoran FPV Talk 1 Jun 13, 2016 11:16 AM
Help! Afroflight 32 Rev 6 - Baseflight - Not Connecting Recker Beginner Multirotor Drones 1 Jun 03, 2016 04:05 AM
Discussion NAZE 32 rev.6 telemetry on RC 7/8 cliff03 Multirotor Drone Electronics 2 Apr 19, 2016 09:46 AM
Discussion need some advice on Afroflight 32 rev 5 Artful Owl Multirotor Drone Electronics 0 Jan 24, 2015 09:08 PM
