Origin EFUN 85-Inch Brushless Sailplane
The EFUN is right at home executing aerobatic maneuvers or soaring. With an 85" wingspan, included electronics, and a price tag under $150, the EFUN makes a great addition to your hangar.
Designed For Soaring and Aerobatics
The new Origin EFUN is an 85" EPO foam glider with a number of great features for the price. Included are two different wingtips to optimize the style of flight you're after. The EFUN is ready to fly with a 2820 1000kv motor, 30A esc, four mini servos, and a 10x8 folding prop. A belly wheel is mounted to reduce damage to the foam when landing.
The Origin EFUN sells for $149.99 and should be shipping in early October 2017.
CLICK HERE for more info on the Origin EFUN sailplane.
Origin EFUN Brushless Sailplane Receiver Ready 85" (1 min 52 sec)
Features and Specs:
  • Construction: EPO foam with fiberglass and carbon fiber spars, assembles without glue
  • Wing: Two-piece with choice of wing tips or winglets
  • Aileron Control: Dual servo
  • Canopy: Removable for access to battery and radio gear
  • Brushless Motor: 28-20-1000Kv
  • Electronic Speed Control: 30A
  • Propeller: Folding 10x8"
  • Servos: Four (1-rudder, 1-elevator, 2-aileron)
  • Battery (required): 3S 11.1V LiPo 1800-2200mAh
  • Length: 40.03" (1017mm)
  • Wingspan: 85" (2.1m)
  • Flying Weight: 40.6oz (1150g) depending on battery
Sep 25, 2017, 03:07 PM
DFS#000178
Rampage's Avatar
What's up with that rudder pushrod?
Sep 25, 2017, 03:51 PM
WAA-08 THANK FRANK!
JimNM's Avatar
Hmmm, kind like the looks of this one.
Sep 25, 2017, 07:27 PM
cbear's Avatar
its priced inline with a umx plane, they should sell like hotcakes
Sep 25, 2017, 10:08 PM
FoxProGT's Avatar
Im kinda interested in this one. I wonder how rigid the wings gana be. I like the changeable winglets. Wonder if the performance difference will be that noticeable. The elevator looks a little small but I still like the look of it.
Sep 25, 2017, 10:55 PM
WAA-08 THANK FRANK!
JimNM's Avatar
I like the high rudder. I want a slope capable ship that won't loose the rudder every other landing.
Sep 26, 2017, 02:00 AM
ConEx's Avatar
In some European countries also available as REELY SZD-54 from Conrad Electronic Link or their partner shops.
Choice between PNP or RtF versions.
Sep 28, 2017, 12:43 PM
Proud member of LISF and ESL
Any feeling for the wing loading?
Sep 29, 2017, 11:01 AM
USA: LakeGeorge, New York
What a deal for such large glider.....EPO?
why not EPP
Sep 29, 2017, 11:10 AM
Buran's Avatar
$150.00 at Tower Hobbies. I had the Origin Wilga; was pretty goof until I crashed it
Sep 29, 2017, 03:30 PM
microheli's Avatar
To heavy for a floater.
Sep 29, 2017, 07:59 PM
FoxProGT's Avatar
This thing is heavier then my Phoenix Evolution.... which i thought was pretty heavy but it does glide better then i thought it would for its weight. This should have a nice glide with its wingspan.........i would hope.
Sep 30, 2017, 07:10 AM
microheli's Avatar
For the glide angle weight (wing load) have no influence. A heavy plane can have the same or better glide angle. The glide angle depends only on aerodynamics, profile and drag.
But the weight increase the minimum flying speed and the sink rate which is also reduced thermal performance.
Oct 01, 2017, 10:34 AM
WAA-08 THANK FRANK!
JimNM's Avatar
The wing loading is less than the eflight Mystique, and that flies very, very well.
From the video, I expect this to be a fun flyer that will thermal...not a world beating thermal duration ship made of gossamer. The radian flies well, but it is not "sporty".... This looks be be a higher speed frame than the radian.
Oct 02, 2017, 04:31 AM
microheli's Avatar
The Mystique fly very well but the reason is because the wing load of the Mystique is much much much better.
Mystique: 33g/sqdm (66.7sqdm, 2,2kg)
This plane: 44g/sqdm (25.8sqdm, 1,15kg)
And the difference is also bigger than it looks because you can't compare "wing load" between planes in different sizes because a smaller plane need a lower wing load for the same performance.
You can use the Wing Cube Load (WCL) if you will compare planes over different sizes.
The Mystique have a WCL of 4
This plane have a WCL of 8.8
The difference is like night and day.
The Conscendo was the best "sporty" and floaty plane on the market and it's hard to impossible to find a RTF foam plane with similar or better performance.
It have more wing area than this plane but only the half weight.
New Product Warlark Pro-85 brushless FPV whoop 48g! YXmotor Micro Multirotor Drones 200 Dec 21, 2018 12:53 PM
Discussion Scratch built 120 inch sailplane mrcliffsr Balsa Builders 8 Oct 24, 2015 07:15 AM
Help! eFun 45A esc Tabasco Power Systems 0 Jul 04, 2011 09:20 AM
Discussion Where is all th efun stuff dix fix Simulators 0 Oct 24, 2010 01:41 AM
Cool Efun day...Trinity, Absolute, Enigma and Kamelot w/vid utcadman High Performance 12 Jun 23, 2008 09:19 PM
