Looking for high speed coupler - RC Groups
Sep 25, 2017, 11:12 AM
Hey guys.
I am looking for an ideas for a high speed coupler for my water jet system that I have been working on. I have a 2mm shaft that I am looking to attach to a 3.17mm brushless motor. I have some rubber couplers that I am using at the moment, but they top out at about 18000rpm. I am looking to crank the engines up to about 25/28k and with that the rubber can't take it, and vibrate.
Has anyone seen anything that could work?
Eric
Sep 25, 2017, 07:46 PM
i need something with a flexibility of the coupler. I can't get the motor and shaft aligned perfectly since the jets are so close to the hull.
Thanks for the ideas. Any others?
Sep 25, 2017, 10:16 PM
Just Plane Nutts
AirDOGGe's Avatar
I know of no flex couplers suitable for high RPM use. Sorry.
Best I can suggest is two rigid couplers with a very short length of flex cable between them. You didn't say what drive you were using.
Sep 26, 2017, 07:59 AM
Love it! Ill do it.
I just ordered a set of Flex cable from eBay and some couplers for them.
I hope this works.
THANK YOU for the HELP.
Sep 26, 2017, 11:30 AM
Just Plane Nutts
AirDOGGe's Avatar
Glad I could help.
Oct 12, 2017, 02:20 PM
Latitudes vs Attitudes
Bob Gaito's Avatar
High speed coupler?
If you're not happy with the flex shaft...take a look at what I use to couple the weed wacker motor to its gearbox in my Egg Harbor...its a spiral cut stainless steel drum..look up universal joints/ coupler images on google you'll see them...they might be adaptable/ available in your size.
Latest blog entry: 1984 Broward Yacht Refurb
Question SimonK - Setting Slower Motor Speed with Limited High Speed vangalvin Multirotor Drone Electronics 0 May 09, 2016 12:41 AM
Discussion Looking for 2mm to 2mm u-joint or flex coupler metoo Racing Boats - Electric 2 Jul 19, 2012 04:33 PM
Discussion High speed opto-coupler/buffer circuits. bigandy DIY Electronics 4 Nov 01, 2008 11:25 AM
Help! Looking for couplers, T-joints, V-joints, etc. for carbon fiber square tubes clipper453 Beginner Training Area (Aircraft-Electric) 0 Aug 29, 2008 01:35 AM
Help! looking for high speed BLDC motor and driver RCEE BUILDER DIY Electronics 1 Sep 29, 2006 02:30 PM
