Sep 23, 2017, 07:00 PM
Question
Is there an "ideal" first time charge charge-rate?
Hi, all,
Lotsa newbie to electric questions today.
Is there a 'best' first time charge rate, e.g., .1C or 1C or .... that gives the battery the longest life or lowest IR or anything else? Or should I just set the charger for max rate and not worry about it?
TIA,
Larry
Sep 23, 2017, 07:02 PM
Recreational Model Plane Pilot
Rhea's Avatar
For what battery chemistry?
If it's Lipo just charge it at the manufacturer's recommended rate.
1C is a good starting point.
Sep 23, 2017, 07:19 PM
Thanks, Rhea.
It is lipo and max rate is 5C, no other rate mentioned....but that really is a bit much for a balance charge...I just thought there might me a best rate for the initial charge cycle.
Larry
Sep 24, 2017, 07:29 PM
tic
tic
thunderscreech
tic's Avatar
Not really.. Some recommend a lower charge rate (and discharge rate) for the first few cycles however tests have shown very little if any change in cycle life or internal resistance if these "break in" cycles are done
Question Do 18650 batteries need to be balance charge when charging for the first time? Zai Fuchigami Batteries and Chargers 6 Dec 08, 2016 09:41 PM
Question Is there an better way to charge batteries jobinseattle Batteries and Chargers 4 Aug 07, 2016 09:24 AM
Discussion "Ideal" lipo charge rate? Bidwin Batteries and Chargers 18 Aug 13, 2013 06:47 PM
First time charge rate rcnutt Batteries and Chargers 1 Nov 02, 2002 07:59 AM
first time charge rates bosley Batteries and Chargers 0 Oct 11, 2002 01:14 PM
