Sep 21, 2017, 04:11 PM
Calm before the storm
Flyboy81's Avatar
Robart Electric nose gear
Ok I am working on fitting a robart electric nose gear into a Freewing A-10. Here is the real question. Do I have to have a separate proprietary box from robart to make the nose gear work? Is there a work around since the plug is different form robart. I am guessing that I will have to have a separate doohickey to make it work properly. I am really perplexed on this one.
Sep 22, 2017, 09:13 AM
Cougar429's Avatar
Are you able to post a pic or two of the unit? What is up with the stock nosegear?
From what I remember Robart paired with Down and Locked to mod their units from pneumatic to servoless. These did require a separate control module. There were aftermarket options, but were not inexpensive:
http://www.wikesrc.com/RETRACT-CONTROL-BOARD-W20.htm
Another possible option would be Eflites 60-120 servoless. I have been using their mains on craft all the way up to 13lbs.
Sep 29, 2017, 12:55 AM
Flyboy81's Avatar
Thank you for the response. I am not sure why this didn't show up in my feed until now? Maybe follow too many threads. Anyway, It is the type A nose gear for 8-18lb models. Yeah it will need a separate board which sucks because I need some beefy retracts for the nose. I thought this would be a good solution but I didn't realize that Robart had their own proprietary "box" to control all of their units until after I purchased it.
Sep 29, 2017, 08:18 AM
Cougar429's Avatar
I found an early set of Lado mains at the Toledo Show and they are quite strong. Only negative was this version was quite slow to cycle.
Oct 02, 2017, 06:47 PM
Flyboy81's Avatar
Slow is fine with me. If I only knew what I know now.
Discussion Nose gear electric retract senormiller Flight Accessories 2 Jul 05, 2017 11:30 AM
Question Anyone had Trouble with the Robart Electric Gear? payne9999 Giant Scale Airplanes 45 Sep 21, 2015 08:35 PM
Question Robart retract nose gear/robostrut orbsah Fuel Plane Talk 7 Jan 06, 2015 12:49 PM
Help! E-flite Beechcraft Bonanaza Electric retract Nose gear help zsultan Scale ARF/RTF 7 Feb 06, 2011 02:01 AM
Discussion Robart nose retract help Zman39 Fuel Plane Talk 0 Aug 16, 2008 03:16 PM
