View Poll Results: Do you own a Star45
I own a Star45 10 32.26%
I own more than 1 Star45 7 22.58%
I'm interested in acquiring/building a Star45 11 35.48%
None of the above 3 9.68%
Voters: 31. You may not vote on this poll
Oct 23, 2019, 11:27 AM
Just Sailing along
Nice fall weather in the forecast, planning to get out with the stars this weekend at Bridgeland.
Oct 26, 2019, 08:26 PM
What a great day to get out on the water. After months of 100+ temps, we finally got a day where it was in the 60's and clear blue skies. Eight Star45 skippers made it out to Lake Bridgeland in Bridgeland, Texas for 4 hours of fun sailing.
Description:
Oct 27, 2019, 05:06 PM
Modeler/ Historian
Stephen Vick's Avatar
Awesome, yep we roasted in Texas this year. great to see y’all sailing.
Nov 03, 2019, 10:37 AM
Another great day of sailing Star's on Lake Bridgeland today, 11/02/2019. Nine Star skippers enjoyed brisk to mild winds and 65 degree weather.
Description:
Nov 26, 2019, 05:32 PM
Hi Sailor_Man,
you never got back to us with the results of the 3D printed parts.
Cheers,
Terry Smith
Nov 27, 2019, 09:12 AM
question for the builders, as I'm getting ready to embark on on this build. i was thinking about a plank on frame build. I want the boat to look nice, nicer than a fiberglass tub
i have the build guide, I have frames.. but my mind was wandering...(dangerous)
I have seen pictures of folks putting tape on the frames, so the hull could be removed and the frames remain for a second build. for the life of me I cannot find the post/pictures
are the stephens aero frames too delicate for this to work?
Nov 29, 2019, 12:06 AM
It's my understanding that the frames are required to provide support for the planks stringers and deck. I removed 1/2 of the frames to reduce weight, but retained the remainder for mounting servos, planks, stringers, etc and the deck. Not sure if I understand your question.
Nov 29, 2019, 08:17 AM
Fred,
I was thinking that if I removed the frames, after planning once they glue had dried, I’d probably save some weight, but I was thinking about glassing inside and outside. So I’d end up with the benefits of a glass hull, but it would look pretty..
A cored boat, glass on each side with a wood core...
Dec 03, 2019, 12:16 PM
Classic wooden RC sailboater
SeattleRCSailor's Avatar
Fred,
I was thinking that if I removed the frames, after planning once they glue had dried, Id probably save some weight, but I was thinking about glassing inside and outside. So Id end up with the benefits of a glass hull, but it would look pretty..
The frames are usually cut from "Lite Ply" which is a poplar plywood and is very, very light. Removing them would weaken the deck structure much more than any benefit gained from removing the frames.
Also, the hull is generally pretty strong and so glassing the inside really only adds weight. Epoxy coating the frames and the inside of the hull, and then wiping out the excess is generally all you need for waterproofing.
Dec 30, 2019, 02:32 PM
The frames from Stevens aero weigh about 3 oz total. As I can build a hull to minimum weight with them in place, I don’t see any advantage of removing them. The way I designed them they also lock the chain plates and jib rack into the hull structure. That alone is worth the weight to me.
Dec 31, 2019, 06:45 PM
What a great way to close out 2019. Eight skippers enjoyed great 60 degree weather with very light winds sailing 6 Star45's and 2 IOM's. Ed, Vicki, Fernando, Don, Dan, Phil, Alex and Fred on Lake Bridgeland.
Description:
Jan 10, 2020, 01:32 PM
any good pics or plan for star cradles.
Discussion All Over the News - Man Charged in Houston Mosque Fire Park_Flyer Life, The Universe, and Politics 9 Dec 31, 2015 12:19 PM
Help! Multi-rotor Hobby Stores in Houston? retrodog Vendor Talk 0 Dec 15, 2015 01:23 PM
Question indoor flying club in Houston Texas or Indoor flying sites in Houston area!! cerralvo78 Scratchbuilt Indoor and Micro Models 7 Mar 31, 2010 08:24 PM
Funny World's Most Disgusting Apartment Is In Houston specialapples Humor 16 Oct 22, 2008 08:00 PM
Discussion I finally found 1/4in. Blucor in S.Houston Cdr.Instigator Foamies (Scratchbuilt) 5 Jan 03, 2008 07:19 AM
