Metal coat "Mick reeves" 3dLab - RC Groups
Sep 20, 2017, 05:57 AM
I have a 3dlab spitfire 1700! So being plastic I was wondering if it would be suitable to apply Mick reeves metal coat? Or would it be more viable to just paint it? How good is the metal coat in peoples opinion? I'm eager to have the model looking real so this is why I'm looking at Mick reeves product. Any tips or information would be greatful.
Sep 20, 2017, 07:50 PM
Hope to get out of life alive
kenh3497's Avatar
I guess if it were me I would fly the plane first to make sure it does in fact fly as intended. Next you need to figure out just how much weight the product will add to the weight of the plane. It may make it to heavy to fly properly. Also balance (C/G) may become an issue with the added weight of the product you apply.
With the above said I'm not trying to be negative. I just want you to be aware of the potential pitfalls. I would hate to see a nice flying plane ruined by having a beautiful but heavy finish on it so it becomes a hanger queen if it survives that long.
I guess what I'm saying is do your research on the product first. You've made the first step here. Keep looking and asking questions untll you have enough data to make a sound decision.
Ken
EDIT: I just looked at the Mick Reeves product. How would common aluminum foil work??? Print a small section of a wing and experiment.
Sep 21, 2017, 04:46 AM
The model will be for display, so weight will not be an issue. I did think of normal aluminium foil but I think the self adhesive foil would probably be easier to use because it's less likely to tear?!
Sep 21, 2017, 06:16 AM
Look at Vallejo Paints http://www.acrylicosvallejo.com/en_US go to model color and then metal color. You can buy them from Scale Hobbies. This line is extensive you will be amazed what is available and what you can do. Can be brushed or airbrushed lots of idea on YouTube
Ken
Sep 21, 2017, 07:22 AM
ARFs Are Me
TomCrump's Avatar
Assuming that the Reeves product is similar to Flite Metal, it should provide the realistic finish that you desire.
It takes some effort, so I suggest that you practice, before applying it to your model.
Discussion mod to a mick reeve 1/4 spitfire wager Giant Scale Airplanes 1 May 05, 2017 04:06 AM
Discussion A good Deal? Mick Reeves Camel Kansaskiller WWI Aircraft 2 Mar 05, 2016 05:25 PM
Mick Reeves Lightning nmacwarbirds Fuel Jet Talk 16 Sep 30, 2004 04:24 PM
Pushing 400 power, The Micro Reaper from Mick Reeve's jet! Adrian Britton Scale Kit/Scratch Built 4 May 20, 2004 10:41 PM
Best Retracts for Mick Reeves Sport Scale Spitfire brobin1 Scale Fuel Planes 13 Dec 11, 2003 05:31 AM
